Question about Allied Telesyn Computers & Internet
No communication to device on coax connection. TX light flashing on coax side. No RX light coming on. I have a 50 ohm terminator on the coax cable. I have moved the MDI switch between the 2 positions (MDI - MDI-X). When I power up my device and the ATMC15 I get the ON LINE light, the TX light, and the RX light on. RX and ON LINE lights go out. I try pinging from my PC via the RJ45 connection on the ATMC15 but get no response.
Benimur
  • 6966 Answers
SOURCE: cobra 29ltd classic : no rx / tx
D23 is the reverse protection diode and it shorting is the primary reason your fuse blew. As you posted, power was applied in reverse, hence other components would also fail. Pls check:
1. D22 - 9.1V Zener Diode
2. TR23 (2SC1096) 9 Volts regulator
3. D19 - 5.1 Zener Diode
4. IC4 (TA7222) - Audio Amp
5. TR14 (2SC2029B/10) - Finals
6. TR15 (2SC2028B/20) - Driver
7. Most capacitors over 220uF (like C123, C114 & C112)
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 04, 2008
2Gigs
  • 141 Answers
SOURCE: WAP54G bricked power led blinking LAN connection shows as not connected
you did not specify where the wap is connected when you pinged it. Try this, connect the wap54g to your pc. Assign static ip 192.168.1.5 on the lan of the pc, then ping 192.168.1.245. if you can ping you should be able to access the configuration page. if the power is still blinking you can upgrade the firmware
Posted on Mar 11, 2008
ButtFuzz
  • 463 Answers
SOURCE: codra 29 nw ltd classic
Hook radio to antenna. Key radio. Pester nearest trucker for radio check on ch 19. Can trucker hear you OK? Can you hear trucker OK? then meter is bad or connection to meter bad.
Can you hear truckers, but they can't hear you? Final Output transistor is bad...
Posted on Mar 20, 2009
SOURCE: UPS has a fault. no power coming out back
change the battery and try
Posted on Sep 05, 2009
  • 1274 Answers
SOURCE: Red RX/TX and red ANT light on my CB
Well,first hand ,some cobra radio,s have red some have green RX/TX lights, but are you modulating? Some green lights turn red. What is your standing Wave on the antenna,s? You need to check it and the output of the radio. To do this you need a watt or field strenth meter. Can get one at Radio Shack. Your standing Wave is ok as long as it is below a 2. That has to be done on the antenna. ..hope this helps...
Posted on Mar 12, 2010
Testimonial: "Thx the rx/tx light is supposed to turn red I found out. Still trying to get the antenna prob fixed though."
Home stereo with outside antenna, when I insert the coax cable into the stereo the radio plays fine until the type f connector touches the radio and that is when the static starts, please help
Hello, Try terminating the other end of the coax cable with a 50 ohm resister. Also .this could happen due to overloading the input with strong signals. If you know some electronics, you could connect two back to back connected diodes(in 4148) at the radio input end to limit the signal level.
Feb 28, 2018 | Radio Communications
MF Digital Scribe 9000 with Picojet disc printer. Hello, could anyone please help with the pin configuration connections of the 9 pin seriel cable to mini din control cable connection from the duplicator...
Have you tried emailing tech support?
http://www.mfdigital.com/techsupport.html
Failing that, and lack of pinout, serial communications can be done with only 4 connections, Transmit and Receive (TX, RX) ground (GND) if you do it with no handshaking. You'll need Data Terminal Ready (DTR) and Data Set Ready (DSR) and or CTS/RTS (Clear/Ready to end). You may have to trial and error it.
Pin 1 - Carrier Detect (CD) - only needed for a modem
Pin 2 - Receive Data (RX) - Cross over with TX
Pin 3 - Transmit Data (TX) - Cross over with RX
Pin 4 - Data Terminal Ready - Cross over with DSR
Pin 5 - Signal Ground (GND) - Goes to other side ground.
Pin 6 - Data Set Ready (DSR) - Cross over with DTR
Pin 7 - Request To Send (RTS) - Cross over with CTS
Pin 8 - Clear To Send (CTS) - Cross over with RTS
Pin 9 - Ring Indicator - Only needed for modem
May 20, 2014 | Computers & Internet
2008 Malibu LTZ 3.6 engine. Diagnostic code B2470 that is an ONStar antenna issue , and P70496 I called Chevrolet Dealer, But these People have lost their minds with the prices they Quoted . ! I need to...
P70496 This is not a code . Has nothing to do with emission's .Now P0496 does P0496
Evaporative Emission (EVAP) System Flow During Non-Purge
Purge solenoid is probably bad .
Automotive Evaporative Emissions Part One
B2470
Cellular Phone Antenna Circuit Malfunction
VCIM
DTC B2470
DTC B2470 04: Cellular Phone Antenna Circuit Malfunction Open Circuit
The cellular antenna is connected to the communication interface module (CIM) with a RG-58 coax cable. The CIM polls the data from the cellular antenna once every second.
Circuit/System Testing
Ignition OFF, disconnect the cellular antenna coax from the CIM module and the cellular antenna.
Ignition ON, test for less than 1 volt between the antenna coax center terminal and ground.
? If greater than the specified range, replace the antenna coax.
Ignition ON, test for less than 1 volt between the antenna coax outer shield and ground.
Test for infinite resistance between the antenna coax center terminal and ground.
? If less than the specified value, replace the antenna coax
Test for infinite resistance between the antenna coax outer shield and ground.
Test for less than 5 ohms at the cellular antenna coax center terminal from end to end.
? If greater than specified value, replace the cellular antenna coax cable.
Test for less than 5 ohms at the cellular antenna coax outer shield from end to end.
Test for infinite resistance between the antenna coax center terminal and the outer shield.
? If less than specified value, replace the cellular antenna coax cable.
If coax cable tests normal, replace the cellular antenna.
Clear the DTCs and operate the vehicle within the conditions for running the DTC. Verify DTC B2470 does not set.
? If the DTC sets, replace the CIM.
Jan 08, 2018 | Chevrolet Cars & Trucks
Cobra 29 ltd Classic no sound, no rx, all lights work rx,tx, lite up. The SWR meter moves when mic is keyed up.
Check speaker and plug external one in if you have it.
swap mic could be a broke wire or bad switch in handset.
check antenna and coax connections.
i know checks sound basic but they could save you a lot of headaches later
May 31, 2011 | Cobra 29 LTD CB Radio
I have a Honeywell Q7055A Building Network Adapter that has stopped working i believe, i have 8 controllers that are not communicating to my front end and the BNA has a solid Tx light lit on it and no...
Usually route modems provide means to linking resources between computer devices . An absence of the computers that provides resources is observable that the router modems continues to blink least with resources sharing taking place. Unless that devices were disconnected mometarily causing signal miscommuciations requires ascertaining main system units to restablish networking. Ascertain that each connection devices, cables, also wireless features has least been alterlated.
Apr 04, 2011 | Honeywell Computers & Internet
I have a Motorola Quasar TV and an outside UHF Antennae. I have coax coming from Ant. There are 3 coax connectors on the back and one pair of screw terminals for 300 ohm flat lead in cable that is...
You are losing a VERY small amount of signal using the transformer. It won't even be noticeable I'm sure if you switch to the coax in but the fewer connections you go through the less the chance of a bad connection. Use regular " Ant. In " coax connection or " RF in" whichever the wording is on the back of your set. Good Luck!
barneyluc
Oct 10, 2008 | Televison & Video
I can't configure my CPS1600
the CPS600 is controlled and configured with the java based vConsole software. vConsole is provided by Avocent. I personally haven't worked with Avocent hardware much myself, but from what I can tell CPS1600 is designed for a UNIX based network. It should work on a windows networks as well, but you may need to do the CCM firmware conversion or update the CPS firmware to enable the device to communicate with a windows machine. I would recommend to forget about using hyperterminal and try the vconsole software, and if your still having trouble, then go for the firmware update and the ccm conversion as a last resort. Here is the link to the Avocent site, you should be able to find all the necessary software & firmware there. If you do end up needing a Unix system to configure the device, you should be able to get away with using the knoppix livecd linux distribution. Its a bootable cd with a fairly user-friendly version of linux.
www.avocent-europe.com
- Shawn
Jan 28, 2008 | Avocent CPS 1600 Networking Switch
How to split WIFI signal between one radio and two antenna?
Hi Philip,
To answer your question, from a single TX/RX device (your WiFi unit) to a dual antenna, what you would need as a splitter is more commonly called a "phasing harness".
A phasing harness is a balanced transmission line which is used when you want to stack or use two antennas from a single radio output. In lower frequencies it is made from a pair of 75 ohms high grade coaxial cable of equal odd quarter wavelengths of the operating frequency. The joint at the middle is connected with a “tee” connector with another cable (standard 50 ohms cable) that runs down to the radio. The free ends of the 2 75 ohms coax are then connected to the two antennas. This  site shows phasing harness for multiple antennas.
For microwave region, since losses tends to be magnified, commercial grade are often used rather than home brewed. Examples are shown in this page.
Alternately and perhaps simpler is to just remove the reflector of the 8Dbi patch antenna of the EOC 3220. Normally in designs such as the 3220, the active patch antenna is soldered on one side of the PCB.  At the back is another which looks just like it but slightly bigger. This is the reflector.  The reflector has two (2) purposes:
1.    block any signal coming in from and going to the back of the active patch antenna; and
2.    reflect any back signal of the active patch antenna and re-direct it forward to effectively increase the front signal.
If you decide to remove the reflector, there will be 3 effects on the performance of your TX/RX device:
1.    the front (major) lobe (roughly the front radiation pattern; maximum distance and area covered of the front signal traveled) will be greatly reduced;
2.    that reduction would be translated to a rear coverage; and
3.    it is highly possible that you will have small side lobes as well.
This   document  would give you an idea on the lobes and radiation patterns.
Good luck.
Oct 24, 2007 | EnGenius EOC-3220 (EOC3220)
Computers & Internet Logo
37 people viewed this question
Top Allied Telesyn Computers & Internet Experts
Prashant M
Prashant M
degroot2940
Are you an Allied Telesyn Computer and Internet Expert? Answer questions, earn points and help others
