Question about Flat Panel Televisions
TV switches input source while watching
When watching cable via EXT1 TV switches itself every few minutes to EXT4 and also frequently freezes as if the freeze button has been pressed. Is this a settings issues or does the Tv need repair
SOURCE: TV freezes when switching to a digital channel
Issue was with the HD channels only.
Updated the firmware of the TV to ver 2.
Now the TV will stutter for a second when changing to a HD channel but it no longer locks up.
Posted on Feb 17, 2008
  • 56 Answers
SOURCE: mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Posted on Nov 20, 2008
  • 16 Answers
The problem your describing can be contributed to your cable box. Depending on your cable company there are times when the box has trouble translating the signal to the tv. You tv is operating normally. Suggest to the cable company to switch your box.
Posted on Dec 07, 2008
  • 60 Answers
SOURCE: Samsung LN-T5281F TV: Control panel on TV is not responding
  1. Need to replace the main Board
Posted on Aug 23, 2009
SOURCE: hdtv picture freeze
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
Posted on Jan 07, 2010
  • 1614 Answers
SOURCE: I was watching ch5 yesterday about 3pm when I
it might need a firmware upgrade, but you would have to contact grundig to see if there is one available
Posted on Mar 29, 2011
0 characters
1 Points
While watching a program the Tv keeps going to a Blue screen at least once a minute.
Hi. First check to make sure the HDMI cable is completely plugged in. If that isn't the problem most likely it's a bad cable or a bad or dirty HDMI input. If you can try another input see if that fixes it, if it does then the first input is bad, if not, then the cable or source is the problem.
Mar 14, 2015 | Flat Panel Televisions
Precision TV - PTV2548 no sound when your watching cable but there is sound forvideo input
may be the source itself(i.e. cable box) also check cables between cable box & TV. If you are connecting the DVD to the same input the cable box is installed, You know that input on the TV is OK. If you get no audio when the DVD is connected to the same input as cable box, then issue is the MAIN PCB.
May 21, 2014 | Flat Panel Televisions
My pc is connected to my tv using an hdmi cord, it frequently cuts out and says no signal
Sounds like either the laptop's hdmi output, or the tv's hdmi input is the problem. You can findout wich one by connecting the laptop to another set and see if it still happens. If it goes away then it is your tv input, if it is still there it is the computer.
Jan 28, 2013 | LG Flat Panel Televisions
Tv keeps changing the source of signal after about a minute so if i am watching cable tv on hdmi it switches to a different input i.e. ext connection after about a minute. it keeps going through the...
You may be the proud owner of devices that subscribe to the Consumer Electronics Control (CEC for short). These devices, via the HDMI cable, can read each others needs. If a CEC supported DVD is connected to your HDTV and the player is powered on, your HDTV will automatically change to that input ( eg: HDMI 2). Conversely if your HDTV is on and you change input to HDMI 2 the DVD player will turn on.
You could try the "masking tape over the TV's IR eye" to see if there is any extraneous Infra Red in the room that might be causing the problem? If it stops check for bright or shimmering light bulbs or Compact Florescent Lights (CFL's)
Sep 29, 2011 | Flat Panel Televisions
T.v. flashes off and on while watching it but doesn't do it when watching dvd's
I'm assuming that the source that flashes is sat/cab connection. If the cable types are the same between the dvd and the other source (both hdmi ?) then try swapping them. If not then purchase a cable to swap(keep the receipt and make sure you can return) to see if the problem goes away. If it is a cable/sat/dvr then try unplugging for about 30 minutes and plug back in. If that doesn't work, then try changing the input where the cable plugs into the tv . . . if its HDM1, then move it to HDM2 and make sure that you switch sources on the tv to new source . . .
The poodle guy
Nov 25, 2010 | Flat Panel Televisions
When i switch my tv on it turn's itself to standby, i can switch it back on again but it just keep's switching itself to stanby after a couple of minutes.
You need a live input source to the port that the TV is set to, or turn on the tv and switch input to a live input source, anything else and the tv shifts to standby.
Oct 13, 2010 | Flat Panel Televisions
DVD to TV- no signal?
make sure all cables are connected firmly and that your on yhe right input mode on tv ( AV1 or AV2 ) EXT1 or EXT2
Nov 08, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
TV sound but no picture
Can you tell me which Cable box you are using?Which model/region?
The possibility is that the HDCP handshake could not have happend correctly and hence the issue. Try to connect to different HDMI input of TV from Cable box. If possible change the resolution of cable box and check video
Nov 01, 2009 | Philips 50PFP5332D 50 in. Plasma...
How do i run a channel scan? there is nothing in the manual
Found this in the most frequently asked questions at the Dynex customer support website on page 3. the website is:( You can also call the customer support telephone number at 1-800-305-2204. between the hours of 7am-12am CST. Give them the model number of you television and tell them you are having problems completing the autoscan of the television. I hope this information helps you with your problem. 1.How do I set up my channels or run an autochannel search? 2.Are you using a cable/satellite box, cable connected directly to the TV, or an antenna? 3.If you are using a cable or satellite box you must use the remote that came with that box to change channels. 4.Make sure you have the correct input selected to view channels via the cable or satellite box. For example, if the cable or satellite box is connected via component cables please press input and select Component 1 or Component 2 to view your channels. If you are using cable connected directly to the TV: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Cable. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Cable System, then press < or > to select your type of cable or satellite system. You can select STD, IRC, HRC, or AUTO. If you are not sure what type of system you have, select AUTO. 1.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all cable channels you receive. If you are using an antenna: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Air. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all analog and digital channels you receive.
Mar 16, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
While playing xbox 360 in 1080p mod, the screen frequently blanks
Most TV's have problems doing 1080p over component. Dial the Xbox back to 1080i. Make sure the big switch on the Xbox AV cable is set to 'HDTV' not 'TV'(common problem) If the problem persists, try plugging into different hookups, use HDMI (if your console supports it) or buy one of the HDMI adaptors from PDP or MadCatz if your console doesnt. HDMI will reduce the clutter and will make 1080p a reality.
Dec 18, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Flat Panel Televisions Logo
102 people viewed this question
Top Flat Panel Televisions Experts
Jaime Hernandez
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
