Question about Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Model 110.85087-400
I have been having problems with heating issues. I have replaed the Termal Fuse twice now. While in the diagnostic test mode, there are no error codes but beebing does exist. All test performed are noraml. Any idea what the problem could be? I have call Sears for a service tech but they are not offering service in my area. If needed, do you suggest a service repair company in the 01501 area code.
  • TADestiny Jan 19, 2008
    Yes, I have checked with a volt-ohm meter. Everything is normal. The dryer does work but no HEAT
  • sweylman Sep 01, 2008
    Dryer will not start but does display a fault code of f 40.
  • 447 Answers
Do you have a volt-ohm meter to check the heating element and thermal fuse??? I take it the dryer comes on and tumbles but doesnt heat up???
Posted on Jan 19, 2008
  • joey  shearer
    joey shearer Jan 19, 2008
    So youre saying that you have checked the hi limit tstat and the heater element itself?? What was your reading on the heater?? Also remove cover where cord connects to dryer. Plug dryer back in and check from red to black should say 208-240.
Not heating on kenmore elite he4 model 1108508
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 30, 2011 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite HE4 Electric Dryer still runs but is not heating. The Manual says it could be 2 fuses or a circuit breaker but doesn't tell you where they are located. Where are the 2 fuses located?
it may be a reset switch on the motor, heating element or thermal fuse, here is a website that should help, Tim
http://www.applianceaid.com/general.html#fuse
Oct 24, 2010 | Kenmore Elite HE4 Electric Dryer
My Kenmore elite electric dryer will not heat. I
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If that’s fine then the Heating Element should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Kenmore Elite HE4 Electric Dryer
HAVE A MODEL KENMORE ELITE He4 ELECTRIC DRYER. IT
Check the burner tube and clean it out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
Thermal fuse
remove the bottom paneland look y the heating element there should be a mini manual down there with a wiring diagram
Aug 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
331 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
