Not sure where to buy a replacement but I just fixed mine today. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of plastic tubing with 1/4" inner diameter and 3/8" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the hole. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. The end of the tube with the hole should be just visible. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
CORRECTION!! The tubing you need is clear 3/16" inner diameter, 5/16" outer diameter. The size is critical to give you a snug fit over the stub inside the pony and also fit into the hole on the tail. The clear tubing will be much easier to work with than a "cloudy" tube... more flexible and should grab the stub inside the pony better.
Kip V
