Canon PIXMA MX700 All-In-One InkJet Printer
Problem for Canon PIXMA MX700 All-In-One InkJet Printer
Canon Pixma MX700 fax and color problems
By whthun on Jan 19, 2008
My MX700 fax picks up at various times into a voice call, even when on the "Telephone Priority" setting. I have tried putting the "Manual/Auto Switch" in the off position, even changed the "Remote RX" ID number and other settings I think are unrelated, but the fax still interrupts my voice calls.
I also seem to have overly saturated photos with either plain or photo paper, although the correct paper setting is used.
Has anyone come across the solutions to these issues?
Comments:
Jan 29, 2008
- Hi again,
The "telephone priority" mode has been in use, as stated in my original post. I tried many combinations of settings and nothing worked.
After talking to Canon tech support many times, they shipped me a new machine. This solved 2 problems. 1) The fax appears to work properly now and hasn't interrupted my voice calls, and 2) my photos are not over saturated (with magenta?), which means my print head was bad.
This replacement is terrific! The prints are fabulous, regardless of the original. The ADF works superbly without jamming or grabbing more than 1 sheet at a time. The software provided is easy to use and effective, with the possible exception of Canon EasyPhoto EX. It doesn't allow manually enhancing the photo before printing. Get a copy of Canon PhotoRecord. It does it all beautifully!
It also helps to have the latest updates on the software. Here's the link: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=15651#DownloadDetailAct
Now, I couldn't be happier with my purchase! The solution is to have Canon send you a properly working MX700!!
Same Problem
Nov 05, 2008
-   Same here - suddenly the mx700 interrupts telefon calls. Didn' do this in the beginning. I tried every single advice, but nothing seems to work. So I contacted canon today - no answer yet.
-   rk1954m
Solution #1
posted on Jan 29, 2008
Somewhat Helpful)
jdhatch001
Rank: Apprentice
Rating: 70%, 3 votes
I think i just figured this out.
You need to find the Fax Menu -> Receiver Control Settings
Click the Fax button, then click menu and the left icon should be Receiver Control Settings.
Change to Tel Priority Mode.
Hope this helps
Was this helpful?
Yes
No
Solution #2
posted on Apr 25, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Just talk to tech support they told me to set it to DDRP so that it will never pick up
Popular Solutions for Canon PIXMA MX700 All-In-One
Questions and Unsolved Problems for Canon PIXMA MX700 All-In-One
Do you recommend Canon PIXMA MX700 All-In-One InkJet Printer?
Answer
Answer
Getting Error code 6A80 trying to print labels from MS Access
Answer
After trying to run perferated card stock the printer never loaded if form the back and then... (More)
Answer
I get an error code 5100. Printer does not start to print. I have checked the printer head and... (More)
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
