Mother board install into a new case.
I need a install manual for this mother board well pdf would be fine!! I need to know where the led lights and switches go i kind of know but i dont. ECS GeForce6100SM-M (1.0) AM2 NVIDIA GeForce 6100S Micro ATX AMD Motherboard
  • 589 Answers
    Genius:
  • 1,665 Answers
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Jan 19, 2008
    See page 12
    1 HD_LED_P Hard disk LED (+) 2 FP PWR/SLP *MSG LED (+)
    3 HD_LED_N Hard disk LED (-)
    5 RST_SW_N Reset Switch (-)
    7 RST_SW_P Reset Switch (+)
    9 RSVD Reserved
    4 FP PWR/SLP *MSG LED (-)
    6 PWR_SW_P Power Switch (+)
    8 PWR_SW_N Power Switch (-)
    10 Key No pin
I need a manual for power sw, hdd sw ,led sw HP dc7600 Mother Board pn 380356-001 380356
I suggest you go to the INTEL Support website. You should go to this page. https://downloadcenter.intel.com/default.aspx
On that page figure out what Motherboard you have. Use that number to locate the page for that board. Then click on that board.
First you should look for the word 'Documentation" Clicking on that should get you to the Manual for your board. Once you get
that page up look for any reference to the manual for that board.
Download the manual for that board. Most of those manuals are
in .PDF files so you will need to have a pdf reader installed on a
machine you can use. Open the manual in the pdf reader and look for instuctions explaining how and where the cables are laid out on the Board. This set of connections is usually called a "Front Panel".
NOTE: These plugs are often shown with + and - signs. You may have to try turning the plugs 180 degrees once of twice
in order to get them working right. The plugs are usually labeled
as follows. PS = Power Switch, HD LED= Hard drive LED lamp.
RESET = Momentary Contact Reset Switch. (Do not use unless
necessary). and Pwr LED = Lamp that lights up telling you the machine is powerd up and ready to go. I strongly suggest that
you do not "guess" at which pins are which. Look them up. That
manual will explain everything you will need to know. Look at the pictures. that will help you understand the layout. Best Wishes.
Apr 24, 2013 | Intel Computers & Internet
I have a new pc case on the front panel connectors their is one hdd led +- and one hdd led plug were do they go my case is a EVO LABS E-6690 BLACK/RED, 12CM LED FAN, INC DOOR AND SIDE WINDOW my mother...
Hi Badboy !
you can type the name on the motherboard on Google e.g : asrock m3a ucc pdf
You will find the pdf manual right away. On the 20 th page you will see how to connect the HDD led .I think the case should only have one led for the HDD if it has 2 leds just ignore it because the motherboard has only one place where you can put that led. Be careful and good luck !
Aug 26, 2011 | Computers & Internet
How do i plug in power button in on mother board? Lost my manual so I can't find the model #. I was just switching my mother board and all other hardware to new case and my power button (or switch or...
> power led,
Runs to the LED (Light Emitting Diode) labelled "power" on the front of your computer-case
> H.D.D led,
Runs to the front-panel LED that lights-up whenever the Hard Disk Drive is being used.
> reset sw,
Runs to the "reset" button on the front panel.
> speaker
Runs to the internal speaker
> s/b sw
Very briefly touch a metal-tip screwdriver between these 2 pins.
If the computer powers-on, you've found the "power" connector.
Nov 06, 2009 | Intel Motherboard
Looking for conection points prescott mother board (533)
Follow this diagram:
Please rate me if i am helpful to you.
Thank you.
Sep 02, 2009 | PC Chips P21G (881038000916) Motherboard
Front panel motherboard samsung harappa-30 PBA:BA59-00905A
i wont to sound drivers for polaris motherbrod
Jun 12, 2009 | Computers & Internet
Power connections for tower led's
The manual in question can be located here
http://download.intel.com/support/motherboards/desktop/sb/d1047103_en.pdf
It is a pdf file, so you will need ADOBE,
I have checked and the pinout for the front panel connectors is there.
May 24, 2009 | Intel D945GTP Motherboard
FITTING MOTHERBOARD
If you have not removed the old motherboard from the case, then you can identify the various front panel connectors as you disconnect them and label them. Some front panel connectors have labels printed on the connectors which makes it easy for you to identify its purpose. If you have already removed the old motherboard then you will need to trace each of the leads to the front panel to see what they are connected to (eg. the LEDs and switches etc).
You will also need to identify on the new motherboard the various connectors for each function, eg power LED, hard drive LED, reset switch, power on switch, internal speaker etc. If you are lucky It may be printed on the motherboard, if not you will need to refer to the manual.
NOTE the LEDs are polarity sensitive, if the LED does not light, then swap the connector around the other way.
Nov 16, 2008 | Packard Bell Computers & Internet
Motherboard
To download you're manual for the D815EEA2, please click the link below.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
You need to go to page 85.
7482c11.jpg Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G
Good Luck!
Have more questions? Please feel free to ask.
Mike
Jun 02, 2008 | Intel Desktop Board D815EEA2 Motherboard
Wiring
Click the link listed below that will take you Gigabyte. Download the manual described as, (English-Rev. 1103, format pdf, size 7.47Mb). The case leds placement is on pg. 25. USB's on pg. 27. Everything you need to setup this Ultra motherboard is here.
http://www.giga-byte.com/Support/Motherboard/Manual_Model.aspx?ProductID=1621
The only thing not mentioned for connecting the case led wires to the motherboard is the wire colors. Which is, pos+ & which are neg -. Usually white colored & black colors are negetive -. Other colors like Green, Blue & red are pos+.
This should make it much easyer to install.
please vote...
Feb 13, 2008 | Mercury P4VM800M7 Motherboard
New installation of mother board
Hi check the cables from the case to the mother board. They should be marked and the book that came with the board will tell you where to connect them. The std markings are HDD [red led] PWR S [powerswitch] RSW [reset switch] PWR LED [case power light] To test if there is no fault in the board or power pack. first visualy check the board to see if you have a red led light on when the power is turned on, if not the problem is in the power pack or the wall outlet. second if the light is on, the bridge the pins marked pwr switch on the board with a screw driver and this should start the computer, if not you have a faulty board. Regards mistyman
Oct 05, 2007 | Select Brands System on board CPU / VIDEO/...
Computers & Internet Logo
245 people viewed this question
David Payne
David Payne
