Dell XPS 410 PC Desktop Logo
Posted on Dec 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the max cpu i can put in my dell XPS 410
Anonymous
Level 2:
  • Expert 100 Answers
  • Posted on Dec 09, 2009
Anonymous
Expert
Level 2:
Answers
100
Questions
0
Helped
59392
Points
281
You can replace the max cpu power for your pc that is compatible to your motherboard or the cpu socket.
How do I change boot sequence on Dell XPS-410 desktop
Hi!
Hit F2 on startup to get into the BIOS. Then, modify the start up sequence in there.
Hope this helps!
Raid failure on Dell Dimension XPS 410 PC
A flag will pop up that says you RAID volume is degraded. Down in the task bar area.
My dell xps won`t stay on
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Fan running noisy
That could be a CPU, motherboard or fan issue.
Have a Dell XPS 410 with 32 OS. Want to upgrade to a 64 OS. Need info
With the 410, you will need much more RAM before having a 64 bit OS becomes useful. I assume that you have the default 2GB. In any case, all you need is to buy a x64 OS and install it.
Friends computer just quit. Replaced power supply. No pwr up
Did you not wear an antistatic band? If not, you have killed your PC.
Blinking yellow power button xps 410 will not turn on
I suggest replacing the memory as the diagnostics lights suggest.
Memory can and does fail in some cases.
1helpful
2answers
Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
XPS/Dimension 410/9200 Desktop, And Virtual Memory!!!!
you can set your virtual memory as high as 512 depending on what you want to do with your pc are you gamer if so reduce that setting if not and you using it for applications setting it higher will acheive better results.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
