Question about Panasonic NN-S950BA Microwave Oven
Turning off before finishing time time cycle
Unit will run for about minute, minute and half then turn off. Doesn't matter what power it is set to. Doesn't matter if you use "Quick Min". Tried to replace Magnetron from known working NN S933BF still did same thing. Are the two Magnetron tubes compatible? Had this problem with the NN S933BF and it was the Magnetron.
  • Anonymous Jan 20, 2008
    shuts off in about 25 secs and displays child
  • Ken Shostad Apr 20, 2009
    I have the same problem, 5 sec. then off....
I have just had this problem where the oven will only run for 5 seconds and then turns off model #NNS561. Cant find any solution.
Posted on Jan 25, 2008
My whirlpool oven turns itself on and off without me touching it have had this problem before and was told it was in demo mode but don't know how to turn it off
I am not sure this is your issue ... but from the Whirlpool web site .. to turn demo mode off: Possible Solutions
The control has been placed in demonstration mode
IMPORTANT: This feature is intended for use on the sales floor with 120 V power connection and permits the control features to be demonstrated without the oven turning on. If this feature is activated, the oven will not work.
1. Press SETTINGS/CLOCK until "DEMO MODE" is displayed.
2. The current setting will be displayed.
3. Press the "1" keypad to adjust the setting.
4. Press START or CANCEL to exit and display the time of day.
Reset power to the product:
There may be a problem with the User Interface/Keypad, or the associated wiring.
  • Power unit down by turning off the circuit breaker(s) for one (1) minute.
  • Power unit up by turning on the circuit breaker(s).
  • Monitor the oven for one (1) minute to ensure the error code does not display again.
  • Verify oven operation.
Jan 09, 2018 | Whirlpool Microwave Ovens
Runs 20 sec stops reads F1E5
Error Code/Message - Oven - F1 Error Code - F1 E5
Control displaying F1 E5:
There may be a problem with the Oven Control, or the associated wiring.
Oct 23, 2015 | KitchenAid KEMS309BSS Combination...
Powers off immediately after starting
My immediate reaction would be to cut your losses and buy a new unit as sooner or later you will run into a part that is no longer available.
Nov 03, 2012 | Whirlpool Microwave Ovens
Rational selfcook oven say service 21
Service 21 refers to your humidity control valve (climavalve) did not make a full revolution in the time allotted (about 20 seconds). Pop open the front control panel by inserting and turning a 5mm allen key into the opening on the top of the oven. While the oven is at the home screen, flip the dip switch #1 on the back of the control board to the up or on position. On the screen you should now see a new icon resembling some tools, like a wrench and screwdriver, click this icon. Go to Basic Settings and scroll to the right once until you come to Basic Settings 1.2. It should say drain valve and flap with some numbers at the bottom. F-t is the number we want to focus on, take notice of the number there, usually 18-20 seconds. Push the start button to the right of flap, this time will change to 0 while the flap is re-initializing. After 20 seconds or so a new number should come up, if it doesn't or it is over 20 seconds by a lot then you need to replace your humidity control valve.
Additionally every time you turn on your oven the climavalve will cycle, checking to make sure it is working correctly, if you interrupt this cycle by powering off the oven you can simulate this error falsly, to rectify the error turn off the oven and turn it back on and wait a good minute for all of the self testing components to finish their checks.
Sep 23, 2012 | Microwave Ovens
Emerson microwave not working 900 watts
The Emerson MW8999SB 0.9 cu. ft. 900 watt Microwave Oven is relatively compact, and certainly inexpensive, but doesn't skimp on functionality. We were surprised at all the options you get with this little microwave. It's only 20 inches wide, 11.3 inches high and 16.1 inches deep yet. The interior can still accommodate a regular size dinner plate or small (10-inch-square or round) casserole. Plus, there are 10 power levels, eight one-touch function buttons, six Express Cook settings, timed and automatic defrost options, and a rotating glass turntable to circulate the food for more even cooking.
We were very pleased with the performance of the Emerson MW8999SB. It did a fine job heating water for tea, cooking a couple of baked potatoes, reheating leftovers and steaming fresh vegetables. Even the automatic defrost proved surprisingly efficient, letting you enter the weight of the item(s) to be defrosted (4-100 ounces) for easy operation. Chicken breasts were almost fully defrosted after one cycle. We needed to stop and separate the food pieces to finish the defrost cycle.
The unit is styled mainly in black but has stainless steel trim around the door and control panel. The smooth touchpad control panel is attractive and easy to wipe clean. We loved the one-touch Express Cook buttons, which let you activate the unit at 100 percent power for 1-6 minutes, by pressing the corresponding number pad. We also appreciated extra touches such as the Start/+30 sec. button, which can be used to start the oven or add an extra 30 seconds each time it is depressed.
It's hard to go wrong when the functions are so simple. The only tricky part was identifying certain codes used on the display screen. When changing the power level, for instance, PL10 is displayed on the screen. Pressing the button additional times lets you toggle through the different levels. Likewise, the Auto Cook settings may need to be pressed multiple times to obtain the correct weight or portion for the food being cooked.
We were amazed that a machine costing so little also offered two-stage cooking, which lets you start cooking (or defrosting) on one setting and finish on another. All in all, the Emerson MW8999SB is an excellent value.
Pros: Touchpad controls, eight one-touch function buttons, six Express Cook settings, two-stage coking option
Cons: Limited interior capacity can only accommodate dishes up to 10 inches, no sensor
Jul 29, 2012 | Hotpoint RVM1435 Microwave Oven
My new Haier microwave isn't working! I just plugged it in for the first time, and set the clock on it. Then I tried to turn it on. No matter what cook time I enter, and then press start/30 sec., nothing...
When it times down but doesnt heat it is typically a problem with the door switches, especially one you just bought, may have been from shipping . A switch or connection may have been disodged when being shipped to you. Most machines have something like 4-5 wswitches, If 1 doesnt report right it will stiop the unit from running. But since some of them are closed it will accept the programing and try to operate. So a lot of times you get fan running and tray turning but no power to the secondary circuits. You will need to find out who does warranty for them or return it where you bought it as a defective unit.
Aug 14, 2017 | Haier Microwave Microwave Oven
My MAGIC CHEF MCO153uw stopped working. It heats
This sounds like a thermal protector is turning the microwave off. If I were to hazard a guess, it would be the magnetron (produces the microwaves) is overheating causing the shutdown. If the fan was not running it would create the same condition by causing the magnetron to overheat.
Nov 14, 2017 | Magic Chef CMV1000B Microwave Oven
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
No numbered touch pad for use setting clock
I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
If that doesn;t work, press STOP / CLEAR then try the above again.
Let us know if it does not work.
Mar 05, 2009 | Sharp Microwave Ovens
Total power loss during use
Check the voltage on the outlet,make sure it is 115v -- 122volts max, any less will cause it shut off, make sure the polarity off the outlet is correct and it is grounded,check all of your wiring connections, if all this is ok replace unit with a different unit or different supplier of unit
Jan 26, 2009 | Microwave Ovens
Panasonic NN-S950BA Microwave Oven Logo
279 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
