Your image count has got to 9999 or something. Look in the setup menu for a way to reset it. To make sure it works, copy all your photos off the memory card and make sure it's empty; it may not like taking pictures and numbering them less than an image that's already on the card.
A few things but the first that comes to mind is that there is a little slid lock on the upper left side of the memory card. This lock needs to be pushed forward towards the gold contacts to unlock the card. Another problem could be tat the 2gig card is full of pictures and needs to be downloaded to your computer. Once this is done the card will need to be formatted to clean the old pictures off and make the card ready for new pictures. I suspect when you take this card out (2gig) the camera defaults to internal memory and yes everything will work as it should until the internal memory is full of pictures as well
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Fuji doesn't seem to have a manual for such an old camera on their web site. You might be able to find an approximation at http://www.fujifilm.com/support/digital_cameras/manuals/#a
Go to set up then Frame and change to RENEW. It is probably on continuous. My camera did the same thing and this solved it. Apparently even thought the card is empty if it is on continuous it will start the picture numbering where you left off last time.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
I've just had the same problem. You need to reformat your memory card (make sure you download your photos first as it will erase everything on the card). Then go into the set-up part of the menu on the camera. In there you should find the option -FRAME NO. This will be set on continuous. Select the option that says RENEW. This will reset the frame number counter. Once you have done this go back into the FRAME NO menu and set it back to continous. You can now start taking photos again as the counter has been reset.
Try opening your My Computer screen, connect the camera to the computer and watch for the new removable disk to show up. Depending on the camera there may be two that show up. Right click on the removable disk/disks and choose format, click start and click okay. This should fully reformat the memory and you'll be able to take pictures again.
