Question about Singer 7442 Mechanical Sewing Machine
Needle position jammed?
When turning on singer model 7442 there is a buzzing sound and all lights are flashing. With the side plate off you can see the needle position flicker but nothing happens. I can't get the lights to stop flashing and the machine to work. What do I do?
    Problem Solver:
  • 12 Answers
First make sure you are using a needle that is recommended by your model. Secondly make sure the needle is inserted correctly. The flat side of the needle needs to be against the flat bar that makes the needle go up and down. After this, unplug the power supply and let it set for a couple of minutes. This gives the computer time to re-set itself.
Hope these suggestions work!
Zelma
Posted on Jan 19, 2008
Singer model 7442 bobbin thread will not catch
have you tried changing the needle?
is the needle in backwards?
is the needle inserted all the way into the needle holder?
clean under needle plate & in the bobbin area for lint or loose thread
did you hit something with the needle?
Mar 03, 2012 | Singer 7422
Almost jammed
This sounds like a bearing failure, I would take it in to a service center and ask for a free estimate.
May 25, 2010 | Singer 7442 Mechanical Sewing Machine
Singer 7442 will not sew
Had the same problem as mommyb2 - it was the bobbin spindel was in the wrong position. Push bobbin spindel to the left and it works for sewing.
Have the same problem winding my first bobbin - pushed spindel to the right to engage bobbin fuction and the machine locks up and wont wind the bobbin. Irig did you bring it in for repair? I'm thinking its broke - which **** as mine is a brand new machine
Mar 23, 2008 | Singer 7442 Mechanical Sewing Machine
PLEASE HELP MY SEWING MACHINE!!!!
Take the needle plate off and turn the needle up and down by hand while watching to see if it is hitting anything. The hook timing could be off.
Feb 19, 2008 | Singer 7442 Mechanical Sewing Machine
Singer 7442 Bobbin Will not wind
I accidentally used 220V for my singer 7442, I don't know if there is a fuse that I can change? can someone help me with this?
Jan 19, 2008 | Singer 7442 Mechanical Sewing Machine
Singer 7442 - Needle hitting bottom
FIRST DETERMIN NEEDLE BAR POSITION TURN STITCH REGULATOR TO LARGEST STITCH, THEN TURN HAND WHEEL TIL' NEEDLE IS ABOUT TO ENTER NEEDLE PLATE.
AT THIS POINT THE FEED DOGS SHOULD BE JUST AT OR JUST UNDER PLATE. IF SO NEEDLE BAR IS, IN CORRECT POSITION,AND TIMING WILL BE SET AT THE HOOK.
TO SET TIME REMOVE NEEDLE PLATE TURN HAND WHEEL SO NEEDLE IS IN LOWEST POSITION. USING A SMALL RULE RAISE NEEDLE BAR 3/32 OF AN INCH ( OR 3 MM FOR A METRIC RULE) .HOOK POINT SHOULD BE IN CENTER OF NEEDLES WIDTH. LOOSEN THE 2 SHAFT SCREWS
SLIGHTLY,TURN HOOK TIL CENTER OF NEEDLE. TIGHTEN SCREWS. IF NEEDLE BAR IS OUT OF TIME. BRING HOOK TO CENTER OF NEEDLE AND LOOSEN SCREW IN LEFT COVER. RAISE OR LOWER NEEDLE BAR TO SET 3/32OF AN INCH. THE 3/32 MUST BE VERY VERY CLOSE.
Nov 26, 2007 | Singer 7442 Mechanical Sewing Machine
Singer 7442 is Loud!
Check to see that lint or oil has not collected on the hook or needle bar. Always use a good quality sewing machine oil. A damaged needle can also be the cause of a noisy machine - insert a new needle.
Nov 21, 2007 | Singer 7442 Mechanical Sewing Machine
Singer 7442 Mechanical Sewing Machine Logo
135 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
