Question about Acer Aspire™ T180 PC Desktop
Ethernet driver after using pc for several months it stopped working due to modem problems since installing new modem pc says no driver for ethenet so cant get internet tried to find correct driver download head boilin somebody throw me a silver lining please
    Problem Solver:
  • 17 Answers
Download this driver and save it to somewhere you can remember:
When it's finished right click on the file and select 'extract all'
On the window that opens make sure 'Show extracted files when complete" is checked and click extract.
Run the setup program in the window that opens and let us know if it fixed your problem.
Posted on Jan 19, 2008
Internet stopped working after lightning strike and new motherboard didn't help
Can you please describe in more detail how the internet doesn't work?
If you have the laptop and the desktop connected to the same router? If so, if you turn on Sharing, can you see the other machine? (or if you have a network attached printer, can you print to it?) If you can do other tasks with Ethernet, then it is not a computer hardware problem.
Does the cable modem have wireless and four Ethernet ports, or does it have just one Ethernet port? Do you have a separate router?
Jun 28, 2014 | HP Pavilion Media Center TV m7480n...
How do i find my modems ip adress
In order to find out the modem ip address
1)Connect your modem directly to the computer using an ethernet cable
2)If you are using windows XP >Go->Start>Run>type CMD>click ok>You will get Command prompt/(black window) type inside the command prompt>ipconfig and hit enter-/under Ethenet adapter local area connections, you will find your ipaddress,ipv4address and the default gateway will be your modem ipaddress
3)If you are using windows Vista >Go to start>type under start search>CMD> cmd.exe will be listed on the top>right click the cmd icon using your mouse>select run as administration>you will get the command prompt>type inside the command prompt>ipconfig and hit enter-/under Ethenet adapter local area connections, you will find your ipaddress,ipv4address and the default gateway will be your modem ipaddress
If you look at the bottom of the modem you will find the ipaddress of the modem
Nov 02, 2010 | Computers & Internet
Lan terminal not working
first check for all the drivers in the device manager.... if every thing is perfect in driver side, then check if the ethernet/ lan is enabled....
then check is the light in the ethernet adapter is lit, when you plug any ethenet cable in it... still if it is not working, then finally try to update the latest driver for the ethernet controller.... if nothing works, then buy an pci ethernet card and use it..... you can also buy external cards like usb to ethernet converter... even belkin manufactures usb to ethernet controller....
May 09, 2010 | ASUS P4P800 SE (890552603657) Motherboard
I just ran the recovery disks to cure a severe
Do you have separate installation driver disks for those items? If not, you can use a friends PC to go on line and download them. You can also get more information under control panel - system - hardware - device manager. The PC will show you which items are having trouble and any information it can get from the component. If it shows unidentified it is very likely the driver is not installed. But note - are you sure it was a virus and not a failing hard drive. If problems return now that you are going it is more likely the HD.
Apr 21, 2010 | Gateway 5200X PC Desktop
D-Link DSL 200 Modem install. prob.
Use your old P2 to go to the manufacturers site of the new pc and download the drivers for the network adaptor. Copy them onto a usb drive and reinstall on the new pc
Jul 31, 2009 | D-Link DSL 200 (DSL-200) Modem
Ethenet port not working
if there is no light on ethernet it might be that the cable is deffective or its not properly plugged in.. and make sure that you're Local Area Connection on computer is enabled
to check:
START menu>> Control panel>> network connections>> right click local area connection and choose enable..
Jul 16, 2008 | Arris SURFboard SB4200 Modem
Router not working
Check the adapter definitions on your PC
Jul 13, 2008 | NetGear WGT624 Wireless Router
Can't connect my ps2 slimline wireless to play online
can not do wirless
can only be wired cause i was asked that not to long ago sorry just buy a multi ethenet cable conneter and another ethenet cable to hook it up to your ps2 that's all i can think of
Feb 10, 2008 | Sony PlayStation 2 Slimline Console
Speedstream 5200 modem
Open the following link --
speedstream 5200
Download the manual from the link and review page 7 for ethernet connection.
Notice particularly the back of the device. There are four connection points to plug things in the one on the left with DSL is where cable with the phone connectors connects the phone jack to the speedstream 5200. On the right the round connector with the pin is where the power goes. Next to the power connector to the left is a USB connector. In between usb connector and the DSL port is an ethernet connector. One way to avoid the need for the USB software os to use the ethernet connector bu connecting an ethenet cable (wider connector that fits snugly in both ports one on the Speadstream 5200 and the other probably present on your computer.
USB driver including VISTA (if you prefer)
USB driver link
Dec 11, 2007 | Efficient Networks SpeedStream 5200 Modem
Ethernet adapter problem
There is not enough information here to be able to identify to a great degree of accuracy what the true problems could be, but I will take a stab anyway. Is it safe to assume that the current configuration has been working in all 3 aspects during the previous 9 months? If this is the case, it is possible that your modem (if it is a cable modem) may need to be reset to acquire a new address. The activity and collision LEDs do not necessarily tell you that you are connected. The headphones problem...possible that you inadvertently disconnected the motherboard connector and placed it on incorrectly while researching one of the other issues? This could also be the case for the audio connector. Double (and triple) check all cable connections to the motherboard to ensure they are in the correct orientation and location. If the above is insufficient feel free to post more detail, such as did it previously work, did you previously install any new hardware and/or software, thunderstorms in the area recently, changes at your ISP? Good luck.
Dec 01, 2006 | ASUS A8N-SLI Motherboard
Acer Aspire™ T180 PC Desktop Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
