Question about Toshiba RD-XS34 DVD Player/HDD Recorder
DVD RECORDER DISC NOT FORMATTING
    Genius:
  • 1,234 Answers
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Posted on Aug 27, 2010
What disc should be used? DVD-R or DVD+R ?
Use DVD+R,
According to the claims of the DVD Alliance, using a DVD+R (or DVD+RW) recorder will provide the following advantages over a DVD-R recorder:
  1. Instantly eject without having to wait for finalized formatting.
  2. Ability to record one DVD disc partially on PC and partially on television.
  3. Background formatting: while the disc is being formatted, you can simultaneously record on already-formatted portions of the same disc.
  4. Enhanced ability to edit filenames, movie and song titles, and playlists.
  5. 100% compatibility with all other DVD players, while still enjoying these extra recording features.
Source: http://www.diffen.com/difference/DVD%2BR_vs_DVD-R
Aug 16, 2013 | JVC HR-XVC20U DVD Player/VCR
My DVD-HR753 will not read discs. A message comes up saying 'this disc cannot be played or recorded'
Original dvd disc,not copy or not another countries datas disc?Same country as the DVD player was bought and formatted Disc?Most likely the disc u trying to play it is in a difference formatted of recording or finalizing data codes inbeted by some patent coded program.Tries play many more other DVD discs,should work find,than the original disc,u trying to play have protected datas or difference format and not same as of ur DVD player main programming firmware.
May 27, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a Toshiba DVR620ku DVD/VCR combo. I have the Format Mode properly set to "Video mode." I put in a new, unformatted DVD-R, and the player should format the DVD, but it doesn't. I click...
My brother had the same problem. Toshiba tech support said the disc was already formatted, so the DVD MENU option would not be available. He went straight to dubbing and recorded to the disc. After recording, the DVD MENU option was then available. He thought the disc was not formatted since it was straight out of the package and he always had to format other new discs. Perhaps your disc was actually already formatted?
Oct 27, 2010 | Toshiba DVR620 DVD Recorder/VCR
Sony RDR-VX530 DVD Recorder / VCR Combo - cannot format DVD+R
is it possible to record dvd+r?
is this machine not only dvd-R
Apr 07, 2010 | Sony RDR-VX530 DVD Recorder/VCR
How do i rewrite over a disc that is full
If you are using a DVD-RW or DVD+RW, you can format the disc by performing "Format". You can format DVD-RW for either video mode recording or VR mode recording. DVD+RW can be format in order to erase all content of the disc.
You may not be able to reformat a disc that is not previously formatted by your recorder an example would be a. DVD disc formatted by PC or another recorder.
Follow these steps to re-write:
Insert a recordable disc.
1 Press [SETUP].
2 Select "DVD Menu",
then press [ENTER].
3 Then select "Format", and
press [ENTER].
4 select "Start", then
press [ENTER].
5 Confirm by selecting "Yes", then press
[ENTER].
Formatting will start.
6 Formatting is completed.
When the disc is ready for you to rewrite to "100%" is indicated.
Formatting 100%
Mar 29, 2010 | Toshiba DR420 DVD Recorder
Recorded DVD will not play in another player
Hey,
Maybe the format of your recorded movie didnt support your player..check out your manual for the supported formats and check the format of your recorded movie.If any of the format in the manual matches your movie format then it will definitely play..
please rate my suggestion..
Apr 15, 2009 | Televison & Video
Failure to accept DvD Ram discs in a Panasonic DMR-E55 Recorder
Possibilities are that the laser lens needs cleaning (use a proprietary cleaning disc) or that - as long as you are sure you have original manufacturers' discs and not fakes - the discs are scratched or dirty.
Feb 20, 2009 | Panasonic DMR-E55 DVD Recorder
Dvd recorder not formating after recording.
My Sony DVD recorder RDR-GX 350 not formating the DISK to enable me to record.What`s the problem with it? Thanks.
Dec 28, 2008 | Televison & Video
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Toshiba RD-XS34 DVD Player/HDD Recorder Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
