Question about Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook
Inspiron 1150 screen is black
Mycomputer is 3 years old and of course out of warranty. The screen is black when I boot up. If I connect to an external monitor, the computer works fine. Is this a repair that requires a professional, or can I get a part and repair myself. Thanks.
Jay
  • 49 Answers
Try this:
put your laptop in external monitor:
in windows xp desktop right click properties.
on the settings tab click troubleshoot... follow all the instructions.
if everything fails, you need a pro that can replace an LCD in a laptop...
Posted on Jan 19, 2008
  • 38 Answers
It is one of three things usually Bad cable at the hinge, Failed inverter board, or failed backlight. Probably inverter. Not to difficult to repair. Check cable first because it is inexpensive and easy. Check the inverter and replace if needed . Sometimes you can buy one used cheap with a bad motherboard and swap the top.
There are 24 black lines (one inch to 3 inches in length). coming up from the bottom of my Dell Inspiron 1545 laptop computer. After awhile the lines start getting squiggly, turn purple and spread out...
Try to connect an external monitor to the laptop if the lines are there then it's the video chip on the motherboard. But if you don't see ant lines on the external then it's the LCD on the laptop and it can be replaced. If you can't perform the work yourself take it to a local repair shop.
Mar 04, 2011 | Dell Computers & Internet
3 year old HP laptop. First screen with diagonal
Hi:
I am not 100% sure, but you could have a problem with the onboard video on your laptop. If you hook up an external monitor to your laptop, and boot to the external screen, this will tell you if your laptop screen is ok, if the video displays the same on a external monitor. To get to the external display, some laptops require that you toggle to them, such as holding down the function key and hitting F8, but your model may differ.
Nov 10, 2009 | HP Computers & Internet
I have a Dell-Inspiron Laptop 1526 I had my hard drive replace by Dell once this year already, when I turn on the computer it starts to work and then stop Running Vista my warranty was up Sept 3 2009 like...
Your trying to downgrade this means you have to use vista cd to format the hard driver, and after the laptop restart, load the Xp. Also sometimes this code comes if you donot use the original xp windows.
Thanks for using Fixy
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Oct 12, 2009 | Dell Inspiron 1150 Notebook
Keyboard not working at all
Keyboard is definitely bad and will need to be replaced but try one more thing just to be sure.
GO into the BIOS by pressing F2 on your external keyboard. In the BIOS, there is an option in there to reset to factory defaults after you do that save changes and exit but after you completely exit, unhook the external keyboard and see if your laptop keyboard works. If not then you know for sure without a doubt the laptop keyboard needs to be replaced.
May 14, 2009 | Dell Inspiron 1501 Notebook
Boot problem on inspiron 1150
Try connecting it to an external monitor.
When you do, as soon as you press the power button to turn on the laptop, close the laptop lid - as this forces the laptop to display on an external monitor.
If this works, then it means the laptop screen is bad.
If it doesn't, the most likely cause would be that the laptop video card went bad.
For a while, some older Dell laptops with high-end nVidia graphics cards tended to die suddenly.
Mar 27, 2017 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Inspiron 1150 lines on screeN problem.
Connect an external monitor to the laptop and see if it also has the vertical lines. If the external monitor looks fine, then your laptop’s LCD display panel is bad. If the monitor has the vertical lines displayed on it, then your graphics card or motherboard is bad.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 10, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Inspiron 1200 Dead Screen
At first glance, I'd say "bad video/motherboard" ...however, when you hook up an external monitor, you also need to first switch into "external LCD" mode. On the Dell laptop, hit FN and F8 I believe to switch between LCD and external. It will go through several modes...LCD only, external only, neither, and both. Keep switching until you see something on the external.
If you never see output on the external, you've got a video/motherboard problem. If under warranty, contact Dell and place a support call.
If not under warranty, you're looking at anywhere from $200-$400 for a new motherboard, plus labor for someone to install it.
Hope this helps - remember to rate :)
Experience:
- A+ certified technician
- 8 years as IT/manager of a 100% Dell-supplied company, with over 1,500 Dell volume annually
- Dell Level II certified technician
Oct 02, 2008 | Dell Inspiron 1200 Notebook
Ethernet adaptor and Local Area Connection 2 cable unplugged
Is that an external usb nic card? you can just directly connect it to the usb port.
Sep 07, 2008 | Dell Inspiron 1150 Notebook
Dell inspiron 1150 laptop black screen
Can you hear the Windows startup noises but can't hear it?
Does it work plugged into an external monitor? (Any good CRT or flat screen should work.
Be sure to plug in the screen before you turn it on.
If it doesnt output to the LCD automatically you may have to hit FN-F8 to switch to external.
If it works on external monitor you are just dealing with a screen problem of some sort - either a bad inverter or backlight in the LCD most commonly...
Let us know.
Dec 17, 2007 | Dell INSPIRON 6000 CENTRINO...
Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook Logo
481 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
