I have cut and pasted a procedure to enable me to display pictures on a form and somehow got to be where I am right now with something that sort of works. Don’t ask me how I got this thing working because I have no clue. The fact that it works is truly a miracle of sorts.
There 3 issues which I cannot get sorted out with my extremely limited access knowledge
Firstly, when I start up my database – I get a “Security warning VBA Macro” which never happened before. I think this has to do with the picture procedure that I copied from the supplied site. As I know I should not have any macros in my system, there is probably one now embedded in there somewhere. If this is the correct line of thinking, can you please help me get rid of it. The second and more irritating issue is when I load my default form: Frm_Contacts_Details_All_Full_Page I get the following error Access cant find the field “Picture_Location” referred to in your expression. I have figured out that this must be in an expression on the form properties somewhere, but I’ll be dammed if I can find it. Please help! And lastly: Why is it that I can only open Frm_Pictures in the default view whereas all the other created forms, I can open and then select the design view.? If these problems can be solved by you, I will gladly send you the shell of teh database sa that you can see what I am actually talking about here.Thanks In advance Rob
Ignore the warning (it's there for your protection). Do a search for your default page and / or insert it into your expression, presumably a script of some sort from (who knows where and being a bit more specific would have helped....grrr). The last problem might be because you have them located in a different area (folder). Check and see. Search (or find) on the name of one that does show and one that does not appear.
Was this helpful?
Yes
No
Popular Solutions for Microsoft Office Access 2003
Hey everyone. Can anyone help me come up with a script that will allow me to import a text file...
(More)
Hey everyone. Can anyone help me come up with a script that will allow me to import a text file that's in the format shown below? I'm trying to import this file into an Access database table. The file has spaces between each line which is what is giving me a fit. Please look at the file layout and example below. Text File Layout: a = Lockbox #: (6) digits and (4) leading spaces. Postions 1 - 10 b = Site ID: (2) digits and (8) leading spaces. Postions 11 - 20 c = ISA #: 10 spaces. Postions 21 - 30. Not used currently d = Cust #: 5 spaces. Postions 31 - 35. Not used currently e = RG Key: 11 spaces. Postions 36 - 46. Not used currently f = Tran Code: (4) digits (4) spaces. Postions 47 - 50 g = Record #: 4 spaces. Postions 51 - 54. Not used currently h = Count #: 2 Spaces. Postions 55 - 56. Not used currently i = Volume (17) digits, zero padded to the left of volume. Postions 57-73 j = Dollars (14) digits, zero padded to the left of volume. Postions 74-87 k = Description: 240 spaces. Postions 88 - 327 l = GL #: 23 spaces. Postions 328 - 350 m = Adjustments: 3 spaces. Postions 351 - 353 Text File Example: 105243 12 4101 00000000000009552 105243 12 4102 00000000000000325 105243 12 4108 00000000000043838 105243 12 4110 00000000000043838
I am getting the message "Module not found" after deleting a form that I no longer use...
(More)
I am getting the message "Module not found" after deleting a form that I no longer use anywhere in the database. If I put the form back - issue goes away. If I rename the form - comes back. Something is calling this form but I can't see what. Nothing references it in VBA, macro, query, etc. Where can I look next to see what is calling this thing?
