Question about Epson Perfection 3170 Flatbed Scanner
Scanning 110 Negatives
How do I scan 110 negatives using the media holdeers provided?
  • Anonymous Mar 12, 2014
    I have a yellow line showing up in the middle of scanned negatives. How do I fix that?
It should work in the 120 film holder, though I doubt you would get very good results unless at a very high dpi setting. You would need to crop the image using the marquee in preview mode.
Posted on Sep 14, 2008
How do I scan negatives?
You can try scanning negatives the same way you scan prints, but the results may not be great. Scanners that are designed to scan negatives usually have some way to put light behind the negative to make sure it scans with enough contrast. They often also come with special holders for negatives. I don't know if your model was specifically meant to do negatives, but you can't hurt anything by trying.
After you scan a negative you need to convert it to a positive. The scanner may have come with software that can do this. If not, IrfanView is a free program that can do that as well as much more. It's a great general-purpose image viewer, so it's worth downloading in any case.
May 13, 2011 | PANDIGITAL PANSCN05 Film Scanner
Hi, I have Canon Pixma MP270. IS it possible to scan photo negatives and change to colour prints. thanks. Blair
A multi-purpose printer scanner cannot scan negatives or slides.
You need a slide scanner or a flatbed scanner that is capable of scanning negatives and slides. Not all flatbed scanners are capable of scanning slides and negatives.
Sep 27, 2010 | Computers & Internet
Chances are that somewhere in your family photo collections you have a bunch of slides and negatives that you wish you could do more with. You may want to include them in your family history, to publish them on the Web, or simply to make digital copies so you can share them with the family.
If you've ever tried to scan a negative or slide on a regular flatbed scanner, you'll know that it doesn't work, and you end up with a pure black scan. In this article we'll show you how you get your negatives and slides into digital format, and what issues you may face along the way.
pixblue.gif Benefits Of Scanning Film
There are some key benefits to scanning film (we'll use the term to include slides and negatives) in comparison to scanning a photo. When you scan film, you can use the full area of the slide or negative, whereas a photo will generally only display a cropped portion of the original. You are also scanning the original source image rather than the color corrected and tweaked version of it that the photo processor has provided you with. The process of turning a negative image into a positive one involves inverting the colors in the image and removing the orange cast from the negative. This would be a complicated process if you were doing it by hand; however, your scanner will provide you with software to do this automatically, or you can purchase standalone software to do it.
Most cheaper flatbed scanners are designed to scan photos and other images that reflect light when it is shone onto them. The problem is that film is transparent and light passes through it rather than being reflected off it. Many flatbed scanners have an optional transparency adapter, which replaces the scanner lid with a larger box shaped ob....
Jun 09, 2010 | HP PSC 1410 All-In-One InkJet Printer
Negatives scan as negatives and not as pictures with the plustek 7300
In the Twain driver for your intellscan, there should be a selection for the type of scan. It should be set to "black & White Negative" or "Color Negative". The program you use to edit the scanned file should be able to change it to a positive if the scanned result is still negative. Programs such as Photoshop, Paint shop Pro etc can use Twain to have the scanner scan directly into them. There the phot (negative) can be edited and saved.
May 30, 2009 | Plustek OpticFilm 7300 Film Scanner
I am looking for instructions on this product.
Step 1: Open the scanner lid and remove the Transparent Materials Adapter (TMA).
Step 2: Place your slides or negatives into the appropriate template. Follow the orientation indicated by the icons on the template.
Step 3: Tip: If you are scanning fewer than the maximum number of negatives with the TMA, cover the empty spaces with the provided light shields to avoid letting any extra light in
Step 4: Place the template on the scanner glass, aligning the arrow on the template with the indicated mark on the scanner bed.
Step 5: Close the scanner lid and press the Scan Film button (or select the Scan Film option if you're using the HP Solution Center application on your PC).
Step 6: In the Scanning from dialog box, click Change Settings.
Step 7: Under Scan Shortcut Settings, select your Scan Type (either Negatives (TMA) or Slides or Positives (TMA)).
Step 8: Under Scan To select Save to file. Then click Scan.
Step 9: Under the Save Location dialog box, click Browse and enter the destination folder of your choice. Click OK and follow any on-screen instructions to finish scanning. The scan will be sent to the destination folder you selected. s.gif s.gif
May 01, 2009 | Office Equipment & Supplies
The light on the lid, for scanning negatives won't move
You will most likely find that the FAU cable that connects the lift up lid part to the lower part of the scanner has at least one fractured wire within it. There are eight quite fine wires and the constant opening and closing of the lid has caused this to occur. Unless you have some micro-surgery skills and a small soldering iron it's off to the scanner shop, I'm afraid.
Mar 17, 2009 | Canon CanoScan 8400F Film Scanner
How do I scan a 35mm film negative with my HP PhotoSmart C6180?
I regret to inform that hp Photosmart C6180 does not support scanning negatives.
Nov 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
Scanning Medium Format negatives
The lamp on the scanner (Cano Scan D1250U2F) is too small for medium format negatives.
Jul 19, 2008 | Office Equipment & Supplies
Scanning 110 negatives
You should be able to do about 12 at a time using the 35mm film strip film guide. What Kind of trouble are you having?
Mar 09, 2008 | Canon CanoScan 8600F Flatbed Scanner
Dull negatives
are you using the a transparency adapter on the negatives?
Oct 16, 2007 | Epson Perfection 3200 Photo Flatbed...
Epson Perfection 3170 Flatbed Scanner Logo
337 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
