Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Temp lite blinks
Tv comes on for a second and then shuts off. temp. lite continues to blink which the instructions for the lite blinking says that the fan is not turning. I put a new fan in and it still just tries to come on but shuts down. lamp is working but also shuts down when the fan does.
  • crown n coke Mar 06, 2008
    i turn my tv on and it turns right back off and the red temp light blinks.
  • 50 Answers
Your ballace is most likely out. If not that your light engine is going out. You may be able to get a rebuilt one from www.vancebaldwin.com it will come with a new fan, and ballace.
Posted on Feb 09, 2008
T.V shuts off and power light blinks.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 21, 2017 | Sharp LC-32SB23U 32 in. LCD TV
Out of the box green light comes on and blinks for 10 to 15 seconds, blue screen on television appears for a few seconds then goes black and red light blinks and nothing happens
Only get Welcome screen and green blinking lite. Then shuts off. Buttons locked out also. Need to get software update V41C-11.3 Mitsubishi-tv.com. Go to support then software update. It will ask for model, ser. First and Last name and E-mail. download. http://www.avsforum.com/avs-vb/showthread.php?p=19844230
Has a link about 1/3 way down that will go right to the download. Very helpful.
May 28, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
AKAI MODEL CFT2716. AT POWER ON TV COMES
AKAI MODEL NUMBER PT50DL24 it turns on then goes off n all th screen says LAMP TEMP WHAT DOES THAT MEAN N WHAT DO I ND TO GET IT WORKING
May 10, 2010 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Tv won't turn on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
if it is 2,2 I have start to finish instructions for this repair in this model.
SD TECH
May 01, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Mitsu model ws-55807 power on for thre seconds then power off
If you come up with the 2, then 2 blink code I have detailed START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS SET.
IF THIS has helped you, rate this solution as I do this here for free.
SD TECH
Nov 21, 2009 | Televison & Video
My picture shut off. Power lite clicks, blinks,no picture
how many times is the power light blinking as thats a error code. 3 blinks is the most famous which means convergence circuit failure.
Oct 26, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Jan 22, 2008 | Sony KP-53HS30 53" Rear Projection...
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
187 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
