-   I have the same problem. Settings is not a menu choice on my phone, so there must be another way to solve this problem that is specific to the MLX 10D. Thanks-   Guest
Aug 25, 2008
-   how do i change my ring tone? -   rachel592
Aug 21, 2008
-   please give step by step instructions on how to change my ring tone on my sakar corded phone. thank you, brenda -   clasistyle11
Jul 31, 2008
-   I got same problem, and still not solve -   Guest
Hi there, don't worry changing ring tone it's a very easy task. All you have to do is go to the main menu on your phone. From there you wanna go to settings, and you should see and option there to change the ringtone. In the other hand if your phone has sound files that can be used as a ring tone, then all you have to is go to the location of that file (it's usually located under "my stuff" "my music" etc) and select the file, from there you can select that file to assign as a ring tone. If you need further instructions you might want to put the make and model of your phone. Good luck!
does the Samsung portable phone- DECT2080-3 have the ability/option to 'switch channels?' I'm...
(More)
does the Samsung portable phone- DECT2080-3 have the ability/option to 'switch channels?' I'm attempting to use this phone to transmit a pacemaker EKG transtelephonically, but the technician cannot obtain a good enough signal. We tried speaker phone and moving the phone closer and/or further away from the pacemaker transmitting device, but nothing worked. If the portable is too close to the transmitter, we hear nothing but static. If too far away, the signal is not strong enough. We tried to find a happy medium, but we could not. I thought another 'plan B' would be to switch channels on the portable, but the user of the phone had no knowledge of how to do this.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
