Konica 7020 paper jam
Paper keeps jamming in #11 RADF. anything I can adjust.
  • jvolk Jan 19, 2008
    I"m not a tech. Is this still possible for me to fix?
One very major we see with RADF's is that someone has pulled a jam in the reversed direction and by doing so has pulled a switch actuater out of position , I suggest you check each switch that you can to see if the switch /actuater is not loose or out of position . Next try cleaning feed tires with alcohol and paper towel to ensure proper feeding.
Posted on Jan 19, 2008
How to clear paper jam 11 paper is cleared but still indicates that its a jam
Then properly the sensor near the jam had it accurator jammed so the copier thinks there is still a paper there. or you mite have paper dust or dust blocking the sensor. Could also be a bad sensor worst case bad main board.
Aug 14, 2014 | Konica Minolta bizhub Office Equipment &...
Dcp 7020 paper jams
DCP 7020 PAPER JAMS SOLUTION1... LASER MOTAR DASTE CLEAN LASER MOTAR
Jan 16, 2013 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 Paper Jam, we keep having the paper jam at the paper exit at the top/back of machine. I've examined closely from front, back, bottom, even removing a few easily removed parts, but can...
This is caused by dirty exit roller. As this machine is a pain to dismantle I suggest that you try and clean these rollers ( 3 or 4 rubber small ) as they rotate. Opening and closing the front door will keep rotating them for you. Use a damp wrm water lint free cloth. I use a compound named Print Clean but metho can be used also.
May 11, 2011 | Brother DCP-7020 All-In-One Laser Printer
The screen says the "back cover is open" and
If you turn the printer off and then back on with a paper jam in it you will get this error message instead of a paper jam message. To clear the paper jam from the back of the printer read the instructions from here: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=mfc7420_all&Cat=11
Jan 24, 2011 | Brother DCP-7020 Black and White Copier
Konica 7145 RADF jams while running two sided copy
Hi ,
good morning; open the upper cover of RDF, clean properly the paper take up roller with aceton or alcohol, becarefull you must unplug the copier from the power source. wait a half hour and plug the copier to the power source.
Oct 25, 2010 | Konica Minolta Office Equipment & Supplies
Paper feed on my Konica 7020 is jamming can you help?
It depends on where it is jammng, if it is in the feed area change paper or clean the feed rollers above the paper tray. If it is crunching the paper look to see what is stopping it and correct it. If it still jams in the machine you need a tech to see why.
Mar 23, 2010 | Office Equipment & Supplies
Konica minolta MEDIA JAM TRANSFER ROLLER
yes 2 things. 1 bad sensor. 2 bad paper. change paper brand and type. use hammil mill 20# long grain brightness90 and above to test. if this works you need better paper. if not you have a bad jam sensor and need a tech to repair ir.
Dec 30, 2009 | Office Equipment & Supplies
Paper jams when folding 8 1/2 X 11 ivory paper; less often with white. Tech says it's a paper issue - so whose colored paper (brand) will work - or is it a design flaw?
Is this paper the same weight/thickness as the white paper?
Are you specifying the settings properly as far as the weight and type?
It sounds like the sensors are detecting a double feed(?)
Try different settings for the tray, and even try a different brand of stock to verify.
Apr 29, 2009 | Konica Minolta bizhub C450P Laser Printer
Paper jam
I strongly recommend a service tech. It sounds like you will need a PM kit,fuser claws and a few DFP rollers.
Mar 21, 2009 | Konica Minolta DiALTA Di200 Copier
Konica 4155 - J16 Paper Jam
First, check if the paper loaded is matched with the copier settings.
If that doesn't solve the problem, carefully check the paper path sensors.
Feb 07, 2008 | Office Equipment & Supplies
144 people viewed this question
k24674
jasbo
jasbo
