Question about GE 24 in. Profile PDW7300G Built-in Dishwasher
Replacement module rinse and cap installation
How do I install the rinse and cap module on the GE profile? Can't seem to find an instruction manual anywhere.
  • 1998 Answers
SOURCE: My GE dishwasher is not
what is the model number of your dishwasher? Thanks Rick
Posted on Jan 20, 2011
0 characters
1 Points
I need an owners manual for a Profile GE Dishwasher
Try Googling (GE)(model)(manual) without parens.
The model should be on a metal plate or label under the dishwasher.
Aug 20, 2016 | General Electric GE Profile Dishwasher 24...
Samsung DMT800RHS Dishwasher Rinse aid cap replacement
It's only available with the complete dispenser. There's a reasonably priced one on ebay right now. Part number DD70-01001A.
Jan 17, 2015 | Whirlpool Dishwashers
My ge e profile made a strange sound...smelled wierd, then leaked all over the kitchen floor and through my basement ceiling... any ideas as to what the problem or fix is?
There are several areas to check..
The wierd smell.. you didn't exactly describe it. If it is a rotten smell or an electrical or burning smell etc.
Also you did not mention where it leaked.. front or back...or under sink..
However I suspect you may have a clogged drain or the dishwasher drain hose was installed AFTER the trap under the sink..or improperly installed lacking a "high loop".. check the manual and inspect the drain hose to ensure it is installed correctly. If it was installed after the trap instead of before you could have sewer gas coming back into the dishwasher.. not good to say the least.
You can also pull the dishwasher out to inspect the drain hose connection on the back of the unit. However that is a pretty unusual occurence.
You can also check the drain inside the dishwasher for debris blockage.. I have also seen unrelated items cause bad smells.. like a plastic lid or untensil that melted onto the drying element.. .so Remove the dish racks and carefully inpsect both drain and element.
Remember the element may be hot if the dishwasher has just finished that cycle.. so be careful!
Check the float.. it has a hood on it.. make sure it moves freely up and down.
A few other areas to examine.. the door and counter top. If the door is hard to close or rubs the couter top underneath you may not be getting a good seal.
Also check the colour of the door gasket.. if grey.. examine the corners.. you may need a kit or replacement parts for this. Go to the GE website for those and the instructions.
Also check the holes in the spray arm for blockage.. even a little bit of buildup can cause them to spray against the front door.. the door is actually more of a water resistant barrier than a totally watertight one.. beleive it or not.
Lastly excess sudsing can cause several problems.. use the reccomended rinse agent and detergents.
Dishwashers make all manner of sounds.. things can shift around during the wash cycles and become struck by the spray arm..
If the plumbing is not done correctly you will need to assess your comfort vs skill levels to correct. If it's just a clogged drain.. you can attempt unclogging up to a degree.. then call in a professional to snake it or even use a device (little camera)to inspect it.
Good Luck!
Feb 10, 2011 | General Electric GE Profile Dishwasher 24...
GE Profile Dishwasher not cleaning - older PDW7880GOOSS
My GE Profile Dishwasher PDW8280N00SS wouldn't clean the dishes. I found what looked like plastic particles along with food particles in the wash arm spray holes. I found that heat had warped the gray flat filter in the bottom allowing food particles to bypass the filter, and I found that the flexible plastic sump inlet was disintegrating internally shedding plastic which clogged the filter to the pump and getting into the pump. This shouldn't happen. The material that the sump inlet is made out of is too soft and porous. I noticed other components in the wash water system made from the same white flexible rubber which is an unacceptable material. I bought replacement parts at a cost of $100 for both and this has solved the problem. What's distressing is that the replacement parts appear to be made of the same inferior plastic. And I have noticed upon closer inspection that additional interior parts appear to be heat damaged (warped). This dishwasher has been used less than 4 years and problems like these in a high end dishwasher are unacceptable.
Sep 15, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
I would suggest you buy some CLR and run it through a full heavy cycle with the washer empty. Be sure to put it in all dispenser areas and sprinkle about 1/4 cup into the washer before starting.
Feb 16, 2009 | GE 24 in. Profile PDW7800 Built-in...
My ge Profile dishwasher will not drain
HI. check the following areas for fualts.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).....
Feb 08, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE 24 in. Profile PDW7300G Built-in Dishwasher Logo
67 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Michael Thomas
Michael Thomas
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
