Question about Canon EOS 400D / Rebel XTi Digital Camera
Manual exposure trouble in studio
Hi, really hope you can help!
just cannot change the exposure level mark by using the instructions in the manual.
settings on camera are:-
1/200 F14 (at mo) ISO200
the instructions state that by changing the aperture and shutter speed, the level mark will change but is doesn't....have just had problems in the studio with the camera taking blank pictures all dark!
  • 3 Answers
Exposure compensation can be dialed through the '+' and '-' keys in the upper right hand side of the camera body. The shutter speed should alone take care of the exposure meter if the aperture is more or less good...
ps: sometimes when we increase the shutter speed to 1/2000 th of a sec..it takes a while to reach the zero mark in the exposure bar since you need to dial more to reach an acceptable shutter speed like say 1/10th ...or 1"...
Regards,
Gaurav
Posted on Feb 06, 2008
I use a sony vx2000, and lately, i've noticed when that the shot gets lighter and darker and then lighter again, like the iris is opening and then closing suddenly. i film skateboarding, and the f
It looks like the camera's autoexposure is compensating for the changing light levels. As you pan around, the brightness of the scene changes and the camera changes exposure to compensate.
Try locking the exposure, using the instructions in the "Shooting with manual adjustment" section of the manual (page 44 in my copy). If you need a copy of the manual, you may download one here.
Feb 20, 2012 | Sony DCR-VX2000 Mini DV Digital Camcorder
I waint to know how to inter sim 14 for toshiba photo copy m/c model e-studio 161
Hi Wahdain,
Its so simple enter the formula given below. First press the C button then press the exposure mode change button ( this is what you used to change the exposure from auto to manual or photo modes) then again C button, then again exposure mode change button then 1 and 4 then start button ( this is what you press to take a copy) Try this and put it right.
Best Regards,
Rakshita
Jul 07, 2011 | Toshiba e-Studio 161 Copier Copier
Hi, I have a Canon Speedlite 430EX II. I use it with Canon Rebel T1i. I don't really know a lot about using an external flash, I'm just an amateur I must say. I just always have it on automatic mode and...
Okay big breath, The Rebel T1i controls the flash (one reason you turn the flash on and off that's it) so you may have simply switched metering modes, with flash you should be on Evaluative mode.
Another thing is the camera may have been programed for TTL in the Menu E-TTL is the "normal" but if it's changed then the changes stays until you change it back.
I think it's the metering mode but if not you need to go into the camera Menu, Flash Control, External Flash, Flash Mode then select E-TTL. I found this all in a PDF manual of the Rebel T1i pages 139 through 141.
Hope this was a help.
Feb 15, 2011 | Canon Speedlite 430EX TTL Flash
Canon EOS 300D which is over Exposing
try adjusting the exposure levels set default zero to negatives untill your sure of the right exposure that you want....hope this helps
Nov 25, 2009 | Canon Digital Rebel / EOS-300D Digital...
I want to know that how to adjust exposure level in sharp 1118 or how to make light copy with diganostics mode
l For manual copy density adjustment, press the AUTO/
MANUAL/PHOTO ( / / ) key to select
MANUAL ( ) and adjust with the LIGHT ( ) and
DARK ( ) keys as desired.
l For photographs, select PHOTO ( ) and then adjust with the
LIGHT ( ) and DARK ( ) keys as desired.
l There are 9 exposure steps indicated by 5 indicator lights. (The
indicators light up one or two at a time.)
Successive pushes of the LIGHT ( ) key will change the
indicator lights in the order (3) / (3•2) /(2) / (2•1) / (1).
Successive pushes of the DARK ( ) key will change the
indicator lights in the order (3) / (3•4) / (4) / (4•5)/ (5)
The automatic exposure level can be adjusted to suit your copying
needs.
1 Press the AUTO/MANUAL/PHOTO ( / / ) key
to select the PHOTO ( ) mode.
2 Press and hold the AUTO/MANUAL/PHOTO ( / /
) key for approximately 5 seconds.
l The PHOTO ( ) indicator will go out and the AUTO indicator
will begin to blink.
l One or two exposure indicators corresponding to the automatic
exposure level which has been selected will light up. The factory
default setting is level “3”.
3 Press the LIGHT ( ) or DARK ( ) key to lighten
or darken the automatic exposure level as desired.
4 Press the AUTO/MANUAL/PHOTO ( / / ) key.
l The AUTO indicator will stop blinking and will light up steadily.
l This automatic exposure level will remain in effect until you
change it again by this procedure.
Automatic exposure adjustment
AUTO
Jul 27, 2009 | Sharp Office Equipment & Supplies
Still dont get it
Hi Mark.
Siorry, but because of a fault with the system I am not able to reach you on the other thread.
Normalizing tracks means leveling volume settings for a group of tracks or samples to mix or combine them together without troubles like the ones you got.
to normalise tracks you can use the function built in on the Korg studio, see normalize in the software help.
When operating on MIDIs also remember that MIDIs are recorded on different channel (example drums, guitar bass guitar).eg:bTd Aerosmith MIDI archive
When you use them on a sequencer, and you operate on the volume, ensure
Mar 29, 2009 | Korg Legacy Collection
Level 2 price change code for plu's casio tk6500
Hi.
This is the rare model without the flipover keyboard, so it is more difficult. You will usually find the second level of PLUs are numbered directly after the first level, so if you have 108 PLUs on the first level, then level 2 will start from PLU109. If you want to be sure, print out the PLU prices using program 6 mode. The instructions should be in the prog manual. Let me know if you still have trouble.
Mark
Dec 16, 2008 | Casio Parts Cash Register PC Desktop
Consistent under exposure
Under exposed should be minus not plus number.
Lucky you didn't buy Canon 5D or 1D- they have focus and exposure problems.
Hope you are not using the pop flash that is on the camera. If you are, then turn off the Red Eyes Modes.
Set camera to manual mode and lower the F number(open up to half or one stop).
What studio lights are you using? Increased the light output of studio by those number and shoot like you normally do.
atdlee@netzero.com
Dec 11, 2007 | Nikon 20MM F2.8 AF NIKKOR Lens
Auto bracketing on a nikon d50
no. if you want more than 3, you will have to manually bracket those beyond the initial three. alternately, you can get a reading for settings then change to manual and continually adjust your aperture setting from whatever under exposure level you want to whatever over exposure level you want.
mark
Dec 09, 2007 | Nikon D50 Digital Camera
My exposures come out inconsistent
You cannot use the E-10/20N in Program Mode with studio strobes. Studio strobes are not compatible with TTL (Through The Lens) metering. You will need to set the Mode Dial to Manual Mode. Exposure is determined by flash output , ISO and the distance from flash to subject. Proper exposure can be determined with a flash meter.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
