Question about Creative Labs ZEN Vision:M Digital Media Player
Screen color has faded
This unit was dropped now the images look faded. Videos play but are hard to see. They appear ghosted.
    President:
  • 4,402 Answers
You can buy a used player on ebay and swap the parts out or send it in to repair
http://www.zenrepair.com/Zen/index.jsp
Posted on Jan 19, 2008
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
Ghost / Overlapping Image
ok you have defective convergence crrection circuit! or maybe the RF Box is defective! can you describe the color of the ghost?
Oct 12, 2007 | Samsung HCN4226W 42" Rear Projection...
Ghost images
Could be a convergence problem----see photo attached and tell me if yours looks ANYTHING like this.
A precise model number would allow me to assist you better.
Mar 19, 2012 | Philips Televison & Video
Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
Sep 19, 2009 | RCA TruFlat 27F520T 27" TV
Westinghouse LCM-22W2 has "ghosting"
Usually, LCD monitor ghosting appears when the cable isn't tight, the cable is faulty, or low quality. The cable should be less than 8-10 feet long. Try using a different monitor cable (they're mostly interchangable) and see if the problem goes away. I'd put my money on the cable or a loose cable connection.
May 13, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
48'' Rear projection picture fading
sounds like your color wheel is fading.
Mar 31, 2009 | JVC Televison & Video
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
Mar 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Flashing (ghosting) on screen when playing DVD's or VCR tapes
I've had a similar problem, It was not the TV or the DVD player but the SCART junction box (a separate unit that automatically sent the live input to the output SCART socket, to fix I just uses a spare empty input socket.
if you don't have one of these units try with a different SCART socket or AV input also try replacing the leads between the player and TV.
Nov 10, 2008 | Digimate DGL32 32 in. LCD Television
PLEASE HELP (Three Ghost Images)
You will need to have or change the convergence correction driver IC's. There are two of them in this TV set. Not a fix for a novice I'm afraid. If you have no solid state repair experience, play it safe and call out a pro to assist you in this repair.
Jul 12, 2007 | Pioneer PRO-510HD 53" Rear Projection...
Creative Labs ZEN Vision:M Digital Media Player Logo
175 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
