Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
Ice maker will not make ice
Hotpoint model # HSS 25IFMB
S/N RA257685
WILL NOT MAKE ICE
NO ERROR CODES FLASHING ON ICE MAKER IT HAS A SOLID GREED LIGHT
I HAVE REPLACED DOUBLE SOLENOID VALVE VERIFIED WATER FLOW INTO TRAY SO FLOW TUBE IS NOT STOPPED UP BUT I DO NOT HEAR IT CALL TO FILL THE TRAY.
ANY IDEAS?
  • OlPoop Feb 10, 2008
    Broke out a big chunk of Ice in the back. Ice maker hasn't worked since. Nothing appears broken and the green light is on. It just doesn't make Ice anymore. Any Ideas?
I replaced the ice maker for $95 and all is working!
Posted on Feb 11, 2008
    Problem Solver:
  • 18 Answers
Well, I managed to get mine fixed. The problem was a small bit of broken plastic that runs on the cam to check whether or not the ice bucket is full. I "super glued" it back together with a "Krazy Glue" formula that says it's good for
plastic. Seems to be working now.
The hardest part was removing a small cover that hides a screw for the removing the cover of the ice maker case.
My Samsung refrigerator Model RFG297HDRS-XAA has 15-E code flashing.
Existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
You might be having two error codes instead of one code
error 1 and Error 5.
Error 1 refers to 1. Ice Maker Sensor:
Ice Maker sensor connector missing, contact failure, electric wire cut, short-circuit, Ice Maker sensor failure.
Indicates an error when the temperature sensed by Ice Maker sensor is higher than 150 or lower than -58.
Error 5 refers to 5. Ice Maker Function Error:
Ice ejector and level failed three times or more.
Jul 12, 2017 | Samsung Refrigerators
Error code 15e samsung refrigerator sise by side bottom frezer
existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
Feb 05, 2017 | Samsung Refrigerators
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Flashing Lights on Washing Machine How to Repair ...
Dec 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
Whirlpool how to install
With the freezer door open, depress the flap on the left. Does the flashing stop? If so, the Ice maker is the problem, not he optics. With the flap depressed is the only way you can test this. Solid light mean good, one flash and a pause means cycling, 2 flashes and a pause means faulted optics. Now for the ice maker, what position are the harvest fingers sitting at? At 2 O'clock the Ice maker is parked, At 12 it should fill with water so if the fingers are in any other position than 2 O'clock than the ice maker will not cycle at it can't. Its possible that the ice maker have a broken gear and will not function as designed. Get back to me if you need more information and a model number would be great. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jun 18, 2014 | Whirlpool Refrigerators
Fim120 flashing green light
is there any pause in the blinking light if so count the blinks and the pause and the seconds blinks this will tell you the error code
Dec 11, 2013 | Franklin Chef 120lb. Ice Maker FIM120
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Ice maker shooting water along wall of freezer
Hi...
You need to check this
Regards
PCmania
Jul 08, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Sub-Zero service manual
Here is a link to the error codes. If there is a fault condition these should be flashing on the display:
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
One this to try is a hard reset: unplug and wait for a few minutes and re-plug back in. Sometime this resets the service condition and will then display the error codes.
Ice is displayed when the ice maker is turned on. Press the ice on/off and it should turn off.
Feb 19, 2009 | Sub-Zero 642
Ice maker quit working
good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
Oct 31, 2008 | KitchenAid KSCS25IN Side by Side...
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
137 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
