Question about Fuji FinePix A345 Digital Camera
Fuji FinePix A345 Digital won't turn on
New batteries installed,memory card in,push on button and a short green light from l.e.d. near viewfinder and...........nothing. Repeat... same!
  • Gem217 Jan 25, 2008
    I have the same problem except my screen flashes whenever i put in the batteries and close the lid, is there no way to fix this?
    Scholar:
  • 135 Answers
Have you tried using high-drain batteries? 2800mah rechargeables should do the trick. My A345 had all sorts of problems until I used expensive batteries and now it's been given a new lease of life! my camera wouldn't turn on half the time, when it did it turned off as soon I tried to use it, the shutter would refuse to open, all sorts of weird stuff - I have had no more problems since changing to better batteries (high-density Sony first of all, now I use rechargeable).
Posted on Feb 21, 2008
6ya staff
SOURCE:
Manuel for A345
You may download the manual and more from here.
Aug 05, 2012 | Fuji FinePix A345 Digital Camera
We have a new Fuji A345 camera, and we just bought an Olympus M+ 2 GB xD-Picture Card Flash Memory Card. The card fits the slot, but the camera when turned on says that there is a card error. The camera...
Yur camera is Compatible with the 1GB,512MB,and 256MB except 2GB xD-Picture Card™ TypeM / TypeH
say thanks is very important to people who share
knowledge rate it
Sep 16, 2011 | Fuji FinePix A345 Digital Camera
Bought a 2gb memory card but camera wont accept. isthere a maximum memory card that this can take
For Fuji FinePix A345 Digital Camera your want to buy XD Picture card.Don't buy SD card. It will the specific card to the camera
Sep 16, 2010 | Fuji FinePix A345 Digital Camera
Install a 2 gb memory chip and camera displays card error
Your A345 isn't compatible with the 2gb cards, only up to a 1gb xD. Here is a link to Fuji Canada's compatibility chart: http://www.fujifilm.ca/x7970.xml
Mar 12, 2010 | Fuji FinePix A345 Digital Camera
What is the largest size memory card that a a345
You must format the card in the camera to optimize it.
Feb 12, 2010 | Fuji FinePix A345 Digital Camera
Finepix a345 will not switch on
Does it power up in playback mode? If you can view pictures try switching over to camera mode and see if the lense will extend. if not then your lens is possibly stuck. possible solution in "THE ONLY WAY I KNOW HOW..." In my tips n tricks section. Also is my email if you want some pictures of an A345 opened up. Cheers.
Apr 28, 2009 | Fuji FinePix A345 Digital Camera
A345 won't turn on
I experienced exactly the same problem with my A345. Check for a small L shaped lug on the inside of the battery cover which should operate an interlock switch located in the recess next to the PUSH TO EJECT label. The lug on my camera had snapped off, although this wasn't obvious until I looked at the illustrations on pages 10 and 11 of the owner manual.
My quick fix was to wedge a piece of matchstick into the recess to lock the switch in its operational position. The purpose of the switch seems to be to ensure that the camera is switched off when the cover is open, but as the battery connection relies on the cover being closed, this is liable to be the case anyway. The only possible risk would seem to be if one attempted to remove the memory card with the camera switched on while being run from an external power supply.
Feb 02, 2009 | Fuji FinePix A345 Digital Camera
FINEPIX A345 SOFTWARE DOES NOT WORK.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 13, 2008 | Fuji FinePix A345 Digital Camera
Turns on only for split second!
I was just trying to solve this exact same problem on my girlfriends A345 and upon inspecting the battery door I noticed a small tab had been broken off. I lined up the tab and just above the memory card where it says push to eject there is a slot. In that slot is a tiny black pressure switch that the broken off tab used to depress. I stuffed a small piece of wire in there and hit power and it works just as it did :) hope this solves your problem as I'm sure these tiny tabs break off without people noticing since the battery door closes and locks without them
Oct 28, 2008 | Fuji FinePix A345 Digital Camera
Not recognizing my camera
Check your Mac OS X version number then go to the website below to download appropriate updater for your finepix viewer program.
Mar 31, 2008 | Fuji FinePix A345 Digital Camera
Fuji FinePix A345 Digital Camera Logo
76 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
