-   Yes, I bought a Sharp VN-EZ1 only to find out it was not the menue was not English. My email is lpotterright@gmail.com
-   lenfriendly
Nov 18, 2008
-   Can't change from *** to Eng
-   Guest
Oct 16, 2008
-   same problem can't seem to change the language from japanese to english. Even read the english user manual but there seem to be no language change option in this japanese version.. Maybe a firmware update would help?-   Guest
sony did not add language option in this camera DCW-T10, if you buy it from Japan. But SONY must provide the solution to this problem. I am facing the same problem....
When turned on, Access comes up on screen, and lens goes in and out several times, then screens says...
(More)
When turned on, Access comes up on screen, and lens goes in and out several times, then screens says to power off then on again, This will repeat when powered off and on again and so on.
flash unit will not open or work in any mode except "easy". If you try to change flash...
(More)
flash unit will not open or work in any mode except "easy". If you try to change flash setting with control button, you get message that "flash settings cannot be changed"
