Question about Harman Kardon AVR 225 Receiver
HK AVR 225 front display not working
I was using the harmon kardon avr 225 receiver and the front panel went out. Radio does not come on, and there seems to be no activity, other than the power light comes on, standby works, and I can see the outside front panel that shows prologic, vd1, surround sound choices Can you help with potential problems the speakers made a loud pop noise when it went out i have already checked the fuses
  • 2 more comments
  • TItus Poulose Jan 21, 2008
    its direct to the wall
  • TItus Poulose Jan 22, 2008
    do you know if could fix it or about how much it would cost to fix it?
    jill
  • TItus Poulose Jan 24, 2008
    someone told me a couple output transistors probaly went bad and the system is in protect mdoe until the fault is repaired
    Genius:
  • 1,067 Answers
Thats not good power transformers in it went bad do u have it on a nice power strip or direct to wall
Posted on Jan 19, 2008
HK AVR 247 no power up
Could be an open internal fuse or power supply failure.
Sep 19, 2016 | Harmon Kardon Harman Kardon H/k Avr20 Mkii...
Harman/Kardon AVR 3650 3D A/V Receiver
Make sure TV's HDMI port is working if it is working check it with a new HDMI cable changing the HDMI cable will fix the problem
Dec 15, 2017 | Harmon Kardon Harman/Kardon AVR 3650 3D...
I have the Harman Kardon AVR 254. Just recently it stopped responding. It will cut on and the volume dial will respond but none of the front panel buttons will. Any suggestions on a fix?
There should be two fuses on the secondary board of the main power transformer. They don't look like regular fuses - they are small round can fuses. These are probably open. HK under-valued these fuses originally, and they need to be replaced with 3.15 amp.
Jan 17, 2013 | Harmon Kardon Harman Kardon Avr 254 7.1...
How can i make the sky remote control th avr 130 (harmon kardon)
Does the sky remote have a code for the HK receiver? If it does, use that code to program it. Most other remotes won't work completely because this receiver uses a seperate button to turn it off...
Mar 14, 2010 | Harman Kardon AVR 130 Receiver
I has one receiver Harman Kardon AVR 85 so i need a part to repair so where i buy it ?
What part and what country are you in?
Contact HK directly:
http://www.harmankardon.com/EN-US/Support/Pages/SupportOverView.aspx
Hope this helps as some older parts are getting scarce!
Jan 12, 2010 | Harman Kardon AVR 85
Harman kardon just went dead
You may have overloaded it. Let it rest and cool down. Check the resistance on the speaker to make sure it is in spec with your amp.
Make sure someone didn't accidentally mute it or bump the audio in source wiring.
Make sure your speaker choice (A or B or both or none for headphones only) is correct.
Apr 03, 2008 | Harman Kardon AVR 225 Receiver
Was using the harmon kardon avr 225 receiver and the front panel went out. .... screen display of the channel number, volume, or menu item does not work. ...
Try hooking up a yellow video wire from the back of the AVR 225 Monitor out. Should be at the end of the 7 or 8 yellow video ports on the back of the stereo. Next plug the other end into a yellow video in on a t.v. Get your remote, (Harmon/Kardon) and make sure the t.v. is on the correct video input and hit the OSD(on screen display) button on your harmon remote. There should be a setting in there that says VFD under ADVANCED menu option that allows for turning the front of your stereo lights on and off and dimming them half way also. OFF/HALF/FULL are the 3 options I believe.
If this doesnt solve it your display may have crapped out on you.
Jan 22, 2008 | Harman Kardon AVR 225 Receiver
Harmon Kardon avr 225
i'm the last person that posted wanted to add that we heard a pop in the speakers when the system went out. We'll be taking the box apart soon to see if we can diagnose it...(fuse?)
Jan 01, 2008 | Audio Players & Recorders
Harman Kardon AVR 225 Receiver Logo
319 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
