Question about Dell Inspiron 2200 Notebook
Dell inspirion 1150 won't boot up
The last time I tried to power up it went into hiburnate on battery. The screen is not coming up, there is no clicking of the hard drive, but the fan is on. Lights are flashing for a second, but then only the power light stays on, and everything shuts down. I have removed the battery, unplugged the power and held down the start button for 30 seconds.
  • techbot Apr 08, 2008
    exact same thing it was working fine last week
  • 38 Answers
I had this exact same thing happen. I tried everything I could think of and find out to try. For me it was a motherboard failure and installing a new one worked. .
Posted on Jan 19, 2008
Can't turn on my mini netbook inspirion - help
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Mar 31, 2012 | Dell (INSPIRION MINI 10) Netbook
My inspirion mini went into hibernate mode, and now won't restart. tried power button, light flashes 3 times but won't come on. tried pulling battery, no luck. Help?
Try this: Disconnect AC power, pull the battery, then press and hold the power button for 10 seconds. Release the button, replace the battery & AC, and try booting.
Mar 09, 2010 | Dell Inspirion Mini 10 Netbook
My dell insprion 1150 do not boot
BEFORE YOU REMOVE ANY DEVICES FROM YOUR COMPUTER REMOVE THE BATTERY AND AC ADAPTER.Pull the battery out and try using the ac only,if this works use a toothbrush and clean the contacts on the battery and the computer itself.You can also remove the memory and the cd rom plus the hard drive.see if it will power up with all these out.Last option with all these removed press and hold the power button down for twenty seconds.
Good luck
Apr 15, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Boot problem on inspiron 1150
Try connecting it to an external monitor.
When you do, as soon as you press the power button to turn on the laptop, close the laptop lid - as this forces the laptop to display on an external monitor.
If this works, then it means the laptop screen is bad.
If it doesn't, the most likely cause would be that the laptop video card went bad.
For a while, some older Dell laptops with high-end nVidia graphics cards tended to die suddenly.
Mar 27, 2017 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell 9400 Won't Start
sounds like bad motherboard/power supply. Just to be sure though have you upgraded the ram? If you have more then one memory chip try siwtching out each one and seeing if it's boot farther. It's possible a dimm went bad or the port it's in went bad. Otherwise motherboard/powersupply
Dec 08, 2008 | Dell Inspiron 9400 Notebook
Not a typical backlight issue
Hi!
You can check the brightness with AC in the BIOS and match it with running in battery or else, when you plug the ac adapter, the lcd goes dim, press and hold the FN buttong and tap the up arrow then reboot and try to see if it will still do it. But still the best way to do it is going to the BIOS by pressing F2 at the Dell logo startup.
Hope this helps!
Thanks,
Karlox™
Jul 30, 2008 | Dell Inspiron 1150 Notebook
Dell Inspiron 2200 Notebook Logo
272 people viewed this question
Alun Cox
