Question about HP PSC 1315 All-In-One InkJet Printer
HP All-In-One Printer/Scanner/Copier- How to scan?
How do you use the scanner? Lost the instruction book and never figured it out.
    Sergeant:
  • 226 Answers
Press on scan button it automatically scans a image what ever you put on the glass. you will find your scanned file in my document folder, my pictures, scan
Posted on Jan 20, 2008
6ya staff
SOURCE:
How to scan using epson s22
epson stylus functionalism printer/copier/scanner
Apr 22, 2012 | Epson Stylus Multifunction Printer/...
I want certain letter to down load to my laptop. I have an HP printer scanner. Tell me how?
Among with the scanner/printer, you recieved a cd with the machines drivers and software. You have to install these two to the laptop to make the machine work. When you install the software, you can use this to scan your letter. It should be called something like "hp solution center" or similar. There would be clear instruction/options there for your task!
Sep 04, 2011 | HP G60-120US Laptop
How can I use scanner on my printer? my printer says it is a printer, scanner and copier. I do not know how to use the scanner. I put a print under the lid, pressed scanner, but where is the picture/print?...
You need to install the software that came with the printer. Then in the HP program group there will be a number of programs, one of which will allow you to scan. Try all the programs if you do not know which one to use (on my printer I have to use the HP Solution centre program).
Mar 02, 2011 | HP PSC 2175 All-In-One InkJet Printer
I just reformat my laptop and lost my installation CD for the HP PSC 1410 Printer, Scanner, and Copier. I am really in need to use the scanner. Anyone can help me?
Well, since your laptop is reformated, chances are you may not have the printer installed .. And you have also lost the CD ..
Which means, you will have to reinstall the printer.
So, you may go to HP.Com and then choose software and driver downloads, in the next screen type in the model of your printer and then press enter.. Like this follow the instruction on the screen and install the FULL FEATURE DRIVER..
This will ensure that you install both the printing and scanning part of the driver..
Sep 07, 2010 | HP PSC 1410v All-in-One Printer
The scanner on my PSC1610 HP printer, scanner, copier is only scanning about one-tenth of the picture and the rest of the picture scanned is black
open the scanner in preview and select all the picture you want to scan by stretching the frame around the picture then scan.
Dec 27, 2009 | HP PSC 1610 All-In-One Printer, Scanner...
Lost instruction manual for hp 5610 copier. Where
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aber12
Aug 31, 2009 | HP Officejet 5610 All-In-One InkJet...
Scanner not found
I HAVE THE HP PSC 750 NEED THE THE RESOLUTION FOR THE SCANNER TO WORK LOST DISC TO DOWNLOAD . HOW CAN I GET THE SCANNER TO SCAN.
THANKS EVI
Apr 04, 2009 | HP PSC 750 All-In-One InkJet Printer
No scan option
uninstall printer software and then reinstall from cd that came with it if you have it if not you can download from hp solution center.
Dec 29, 2008 | HP Photosmart 2575 All-In-One Printer,...
Scanner problems
Hi
Try this it has worked for me. Go to hp.com/uk/diagnostics from here you can do a check on your printer to see if it is compatible etc as i found out that the scan button on the hp1210 is the problem. There are instructions after you do the check to either try the scanning with windows fax and scanning or for me it worked with scanning with paint. good luck !
Trap55.
Nov 08, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
161 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
