Question about Copystar Royal - NC4A NETWORK BOARD 10BASE T/2 (00108090) Print Server
Copystar Royal - NC4A NETWORK BOARD 10BASE T/2 Print Server?
I have a copystar 5350, which does not have a network board; I need to know what and where to purchase such a board; my internet search usually leads to toners etc; any help will be much appreciated
Thanks,
Pardes
  • 523 Answers
Here you go the official service site for copystar and kypocera, contact them and they will help you, if not , look for any copystar dealer can help you.
www.kmaconnect.com
let me know wat happen, if you didnot find any solution let me know where is ur location so i can hook you to some dealer.
Regards
Posted on Mar 01, 2009
Star micronic sp700 ethernet problem
10.x.x.x subnet can't see 192.x.x.x network. There must be manufacture reset button on the Star micronics sp700?. You can configured your laptop/computer IP to 192.168.2.100 (not the same as printer) than use crossover ethernet cable (you can find it in best buy), connected directly between your laptop and printer, you should be able to see it on your browser now.
Most people big mistake when assigned static ip. First you need to reserve that IP on your router so it doesn't get pickup by DHCP and assigned to another devices.
Mar 20, 2014 | Star Micronics Star IFBD-HE07 - Print...
On Feb 15 2014, 12:35 PM
sir if you want to make the copier as network copier then go for a print server. it will be cheaper and it will allow your machine in network. print servers are found in computer shops
Feb 19, 2014 | Kyocera Copystar CS-1635 Copier
Copystar CS-C3225 color copier scanner. The Scan to Email quit working. It says Unable to find SMTP server. A Windows box and an iMac print to this. We updated the driver on the iMac for this and n
Updating a driver would not affect the mail server settings. could be a firewall issue but i doubt it. is the smtp server on your lan or are you using a hosted mail solution? the only things that matter there are the ip address of the smtp server, authentication, ssl (or not), port numbers, default from address, dns settings, and message size. the mail function is totally independent from you computers operation unless an on site server or workstation is hosting the smtp server.
Jan 10, 2013 | Copystar Cs-C3225
Fs5350dn wrinkles envelopes when using the envelope switch button
Hi, I am having a serious challenge printing to the FS-5350-DN from work or anything, it simply just restart the application and reopen the document. It used to work just fine, but all of a sudden this starts to happen. this is from a select number of computers though, both windows XP and WIndows 7, but funny enough I can print to another FS-5350-dn on the same network from other computers to the same printers. These printers are all on one Printer server, we are also using papercut...
Can someone say what is going on here?
Oct 08, 2012 | Office Equipment & Supplies
What is the difference between Apple M0436LL/A coax cable and Apple M0436LL/B coax cable.
Both are 10Base-2 ethernet
M0436LL/A is self terminating
M0436LL/B is not self terminating so would need a terminator at the end of it
May 02, 2011 | Apple 42 ft. Coaxial Ethernet 10Base-2...
My HP 4100tn will not print and I am getting error message as follows: 82.0180 EIO 2 ERROR I printed a document and then when I tried to print another document I got the error message. How can I fix...
Thank you for contacting FixYa with your printer inquiry.
This is an error caused by the jet direct card in your printer, try one of two things.
  1. Move the Jet Direct card from port 1 to port 2 on the printer.
  2. Replace your jet direct card with one that you know is good.
Test to see if either of these resolves the issue.
The problem is usually a faulty card.
J7934-69011 JetDirect 620n internal print server - 10BaseT and 100BaseTX LAN interface board - Plugs into peripheral EIO slot - Has an RJ-45 connector
Vender
http://www.dectrader.com/J6057-61001-New-HP-JetDirect-615N-internal-print-server-10Base-T-and-100Base-TX-LAN-interface-board-Plugs-into-peripheral-EIO-slot-Has-one-RJ-45-connector.html?utm_source=googlebase&utm_medium=shopping&utm_campaign=parts
image.php?type=p&id=223008&t250=y
Hope this helps helps. Please keep us updated and remember to rate this answer.
Feb 22, 2011 | HP LaserJet 4100n Printer
Kyocera will not print without kprint port
The KM-1650 will print useing a standard TCP/IP port printing over the network, I have done it ever since the machine came out. Load the print driver as a local printer and then setup a TCP/IP port and set the printer to print to that port in the printer properties.
Let me know if yo need more help.
Jan 15, 2010 | Kyocera Copystar Printing Systems -...
What do I need to get my Copystar cs-2030 on a network in order to scan and print? Is there a network card that needs to be installed?
you need a print system k... print card... and a scan system a card...call a kyocera dealer... they will also network it for you... for the price off those two you might be able to buy a km4035 with those two options installed and pay a local tech to network the copier...
Dec 16, 2009 | Copystar CS-2030 Copier
Laserjet 2300d hasstopped printing to a HP Jetdirect 170x suddenly
parallel cable connected?
omg this? "old centronix")
IEEE 1284 standard
parallel-zw1hxsxncju1x1hxxv3nm1gz-1-0.jpg RTM yet? check the manual carefully
http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=27317&docLocale=en_US&docId=emr_na-bpj06151
The HP JetDirect 300X provides connectivity to 10Base-T and
100Base-TX networks. The HP JetDirect 170X provides
connectivity to 10Base-T ne
tworks. The HP JetDirect EX Plus
provides connectivity to 10Base-T and 10Base2 networks.
HP JetDirect 170X (J3258B):
Bidirectional parallel port (IEEE 1284).
Network port (Ethernet): RJ-45 (10Base-T).
Test button (sends print server configuration page).??????????
2 LEDs on front indicate LAN activity/status
Mar 06, 2017 | HP Jetdirect 170x Print Server
Computers & Internet Logo
83 people viewed this question
Top Copystar Computers & Internet Experts
David Payne
David Payne
Are you a Copystar Computer and Internet Expert? Answer questions, earn points and help others
