Maytag 24" Built-In Single Electric Wall Oven - White Logo
Posted on Dec 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY 24 INCH BUILT IN SINGLE WALL OVEN DIGITAL TIMER
MYmaytag 24 INCH BUILT IN SINGLE WALL OVEN DIGITAL TIMER BLINKS 88.88 AT ALL TIMES. Can I reset?
Anonymous
Level 3:
  • Master 1,891 Answers
  • Posted on Dec 09, 2009
Anonymous
Master
Level 3:
Answers
1891
Questions
0
Helped
409042
Points
5205
Turn power off at main box the back on retry st set clock . if it won;t set / replace it . it has gone bad .mm
Frigidaire FEB24S5AB 24 inch F10
Hello friend, thanks for the post!
I understand your Frigidaire wall oven is flashing a F10 code and not heating up. Based off of that information an F10 code stands for a runaway temperature, which could be an issue with a sensor probe or oven control. It could possibly be a miscommunication with the board and that could be cleared out by resetting your appliance. To reset your appliance disconnect power to it by unplugging the oven or flipping the household circuit breaker for ten minutes. If that step does not resolve your issue and you continue to receive the F10 code I would recommend contacting a technician to come and repair your appliance. I hope this information is helpful. -Matt
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Maytag 24 " wall oven gas trouble code F5
Hi ngwhite,
The trouble code F5 is a Watchdog and hardware conflict. You need to replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
2helpful
My GE Model JCTP18WA5WW IS FLASHING F7 AND THE TIMER CANOT BE SET,ALSO THE OVEN CANNOT BE TURNED ON.
Hi
Thanks for using FixYa. Error F7 on your GE oven means that the keypad is shorted or stuck and to resolve this issue you’ll have to replace the Electronic Range control (ERC).Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
What does the F 5 error message displayed on Frigidaire - 24" Built-in Single Electric Wall Oven FEB 5 56cbs mean?
Hello there:
Here is what the code means and what needs to be dne to resolve this problem
F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control)0dd70e1.jpgShould be something like this
I bought a used 24 inch GE gas wall oven, changed it over from natural gas to lp and it will not ignite they glow red but no flame
Many times, unless you have the universal, the orficies have to be changed. From nat to LP. they do make a universal type.
Gas connection on bottom of oven does not accept std 1/2'' flex hose?
all gas connections are flair fittings if the 1/2 inch is to large a 3/8 inch is the mext size down. if the 1/2 is too small the next size up is 5/8
After a complete self cleaning job, the oven was not responding.
Reset the clock. if power lost at any time failsafe reset mode? see handbook! this is just a guess. cheers Mark
Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
8helpful
F3 and f5 error codes on maytag gas wall oven
(((F-3)))
This is a Shorted or open oven temperature sensor (RTD). Check the following.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
(((F-5)))
This is a Watchdog and hardware conflict.
This is not repairable. you will need to replace the control board or (erc)-(clock)
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
