Question about Panasonic PT-56WX53 53" Rear Projection HDTV-Ready Television
Red bulb i cant get the red bulb to line up on the screen. using the converge moves it but not enough. do i need a new bulb or is there a trick to fix this problem. its a 56 inch wide screen 3 or 4 years old
  • PKeel80 Jan 19, 2008
    I have the same problem a curving double image on half of the screen.. Red is not lined up. Can adjust some but not enough.
    President:
  • 4,402 Answers
Convergence amp ic are bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 19, 2008
Blue line convergence not working
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Projection <a href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target="_blank">TV</a> sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look <a href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target="_blank">3D</a>, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. <br /><br />This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem. <br /><br /><b>Common Symptoms include....</b><br /> <ul class="h_mi"> <li class="h_mi">Screen looks 3D <li class="h_mi">Colors don't line up <li class="h_mi">One or more colors can't be adjusted when using the convergence menu. <li class="h_mi">Screen is bowed or warped. <li class="h_mi">TV shuts off after powering on. Power light will blink. TV may also make a chirping noise. </li></ul>Here are some <a href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target="_blank">photos</a> of convergence problems.<br /><br /><img class="h_mi" src="/uploads/images/42D3683.jpg" /><br /><br /><img class="h_mi" src="/uploads/images/7859B01.jpg" /><br /><br /><img class="h_mi" src="/uploads/images/E87380C.jpg" /><br /><b>Here is a quick tes</b><b>t....</b><br /><br />Using your original remote go-to the settings menu then goto the convergence section.<br /><br />Try to adjust the red and then the blue convergence.<br /><br />You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight. <br /><br />If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem. <br /><br />Note: If you TV has as flash <a href="http://www.fixya.com/#" target="_blank">focus</a> or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix<br /><br /><b><img class="h_mi" src="/uploads/images/69189A5.png" />CONVERGENCE SOLUTION<br /><br /></b>You can see some more examples and find a fix using this link on Fixya <a href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull" target="_blank">http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull</a></span>
Aug 26, 2010 | Hitachi 43FDX01B TV
SCREEN IS HIGHLIGHTED RED, ALL WORDS READ IN RED AND THE PICTURE IS BLURRY ON PHILIPS MAGNAVOX 9P5034C101
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 13, 2010 | Televison & Video
Convergence
  • Screen looks 3D
Jul 06, 2010 | Mitsubishi WS-65869 65" Rear Projection...
My big screen tv looks 3d and red green blue are off
  • Screen looks 3D
Mar 06, 2010 | Sony KP-51WS500 51" Rear Projection...
Red and green lines, kind of 3D looking???
  • Screen looks 3D
Feb 28, 2010 | Hitachi 43UWX10B 43" Rear Projection...
I have red and green lines with a 3d effect on my screen at the bottom
  • Screen looks 3D
Jan 21, 2010 | Toshiba 46H83 46" Rear Projection...
Has blue shadows
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jan 09, 2010 | Hitachi 50UX26B/27K 50" Rear Projection...
Ther is a red line on the left side of the tv the blue an green is alright but it looks like it is in 3D i have tried to line the conrv- but still nothing the red is shifted 2 inchs to the right
  • Screen looks 3D
Jan 04, 2010 | Mitsubishi WS-48515 48" Rear Projection...
Red, green, and blue lines at bottom of screen, mirror looking effect, also looks like 3D. Got at a garage sale so no manual.
  • Screen looks 3D
Jan 03, 2010 | Hitachi 43F300 43" Rear Projection...
My picture is suddenly distorted. It looks as though a bulb is suddenly out of alignment. It is nothing the convergence controls will fix. How do I open the TV without breaking something so see what is...
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 02, 2010 | Toshiba 50H82 50" Rear Projection...
Panasonic PT-56WX53 53" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
