Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite Smartwash QuietPak9 He4t Front Loader -flashing F and H
I put a load of clothes in washer and water fills up then it stops its cycle and starts beeping and flashing F and H. Start the "spin/drain" cycle and try the load again. Same results. Sears has come out on 3 occassions and only tell me that its unbalanced and I need to put bleach and vingar in the cycle w/ the He soap. We are now at our 3rd house and its still doing the same thing. You can't tell me that the floor at 3 different house are all unbalanced. Sears only wants me to purchase another warranty. What do I need to do??
  • Wendy Wofford
    Wendy Wofford Jan 23, 2008
    This solution was helpful. I now know that it's the water level. But did not know to check the pipes to make sure they were empty of all debrie. I did that as a last resort and found that we had concrete from the building of new house in our plumbing pipes. We should have drained/flushed the pipes before hooking up the machines. All is working fine...........at the moment. But the smell continues.
  • mikelwagner Jun 22, 2008
    HE4t displayed FH error code 1 minute into wash cycle during water filling. No debris found in hot and cold hoses or on inlet screens. Water flow appears to be unrestricted thru hoses to machine. Used drain & spin cycle to remove water in tub and tried wash cycle again with same results: FH code. Tried other wash cycles with same error results.
I had the same problem and I had to call my father-in-law. We took the top of the washer off and found the sensor that it talks about on this site. He said that there is a wheel in the plastic casing and it tells the ccu how much water is coming through. He said that I might have some calcium built up in the casing. He tapped it a couple of times and reconnected everything back. Now the machine is working fine and no more problems or codes. The sensor is easy to find. It is the one that is connected to the hot and cold fill valve and then it goes to the white sensor. That is the one that he tapped on.
Posted on Jul 12, 2009
So i put a load of clothes in the washer and i get this SUD message. what does this mean?
Posted on Jan 14, 2010
I had a "SUD" message today for the first time. What is it and what does it mean? Janice Lee, Atlanta
Posted on May 23, 2008
  • 447 Answers
F H means that no water was detected entering machine
Is the water coming in just as fast as it always had????
If indeed the water is fine than there is a sensor called a flowmeter that tell the CCU if and how much water has entered.
It also uses a water level pressure switch to monitor water level, but ive had 0 problems with this switch
Posted on Jan 19, 2008
  • joey  shearer
    joey shearer Jan 24, 2008
    You said something about a smell???
I was having the same problem. After trying everything else, i tried COLD wash and COLD rinze. It does not beep!
Posted on Nov 03, 2008
Kenmore elite smartwash quiet pak 9 he4t won't engage when start button pressed.
The start button operation could be erratic, indicating the need for replacement.
Dec 12, 2016 | Kenmore Washing Machines
My kenmore elite smartwash/he4t
The "F11" fault code will display if the Motor Control Unit (MCU) has an internal failure; repeating under or over voltage, or over current conditions. If failure occurs during high speed spin the door unlocks after 3 minutes. The MCU (Motor Control Unit) is located beside the motor. Here is the part to order.
Dec 02, 2012 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4T standing water
I also have standing water after a wash cycle, but not immediately after. Given the history of very expensive repairs to this Kenmore HE4T washing machine, I suggest you do what I do, if the machine is still cleaning the clothes. Whatever cycle you use, try to be around when the machine finishes, so that you can turn off the water supply and remove the damp clothes to the dryer or clothes line. Turn on the water supply only when you want to use the machine. This works for me because I don't do many loads per week and my laundry area is right next to my kitchen. If it was in my basement, I'd have replaced it already with a top loading machine with mechanical not electronic controls.
Aug 21, 2012 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Kenmore elite smartwash quiet pak 9 he4t the washer starts filing water when the washer is turned off.
This is symptomatic of a malfunctioning water control valve- not closing fully- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 19, 2011 | Kenmore Elite 45986 Front Load Washer
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
He4t kenmore elite smartwash quietpak9. keeps flashing F2?
"F02" is a Long Drain error. This is an indication that there's an obstruction somewhere in the drainage system. Most commonly, the drain pump reservoir needs to be checked and cleaned. The access screws are on the bottom front edge of the lower toe panel directly below the door. You may need to prop up the two front feet of the washer to access them (a 2x4 works well for this). The following link explains:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased online at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Mar 02, 2010 | Washing Machines
Water softener goes in at wash cycle rather than rinse cycle
if it has to go in the rinse,,this means you have to put it in the fabric softner compartment of the dispencer,,,also do not fill pass mark fill line in dispencer or it will sphion down by itself before time..onthejob
Jan 25, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
New Kenmore Elite Front Loader will not get past 'Sud' cycle,
Hello wheeljc; I had the same problem when I purchased my Kenmore Elite in 2006. I have a HE4t front load. It's possible that you're using to much detergent, if you're using HE liquid it only requires a small amount and does a very good job.
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
4,277 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
