Spins but water won't drain out.
Whirlpool quite wash II does not drain water out.
Probably because a woolen mat was put in for wash. Mat had caking rubberized type of backing. We have fished out all the pieces and particles out but it spins but water will not drain out.
washer want drain water
  • saciandus Jan 22, 2008
    Thanks for answering my problem. I will try that if that dont work I will call the repair man thatnks again!!!!!!
  • 447 Answers
Yep that rug backing has totally clogged hoses, drain pump.
will have to be dissasembled and cleaned. You could try some creative things like using air pressure to try and clear the tubes.
Posted on Jan 19, 2008
Stops during rinse cycle and won't pump the water out
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
When I wash a bath mat the spin cycle never takes most of the water out of the mat so it is heavy with dripping water and difficult to put into the dryer. When I put on only the 'final spin' cyle it...
If your bath mat has a rubber backing, that would prevent the water from being centrifuged out of the mat. Even if you laid the mat in the drum with the wet side outwards, it would still only have a limited effect on removing the water.
Jan 26, 2011 | GE Washing Machines
Machine is stuck on spin
Your smart washer equipped with fusion logic got confused at the different scenario that you just changed from automatic to manual mode.
1- Unplug the pwer cord. Open the door to get the the crazy floor mat out to dry under the sun or manually squeeze it before putting in the dryer to take are of the problem at the first place.
2- Pug in the power cord and start with a short run with an empty load to make sure the problem is not happen again then you are good in resetting it. Good luck.
Apr 21, 2010 | Whirlpool GHW9200L Front Load Washer
Whirlpool lsr8233eqo machine won't agaite or spin will drain
check belt,it mite of came off when unbalance.
or if it is a 2009 model,unplug wait 30sec. plug back in. hope this helps.
Oct 04, 2009 | Whirlpool Washing Machines
Calypso washer - LD Code - clothes still wet
harborstuff,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
-samson39
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
Jul 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have a bath mat that I washed in my duet washer successfully twice. Now when the cycle is complete the bath mat is drenched and apparatly no water was extracted from it. I'm frustrated. Another frequent...
Out of balance with wet, heavy rug.
Bathmat is border-line on being excessively heavy (wet)
Do not use in washer. The fact that you got away with it before is your hint NOT to do this again or else bigger problems???
Apr 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Not draining
what happens once it quits and you advance the timer back to a nother spin cycle does it spin or does the motor not start back
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
clean out pump by opening and removing debris
Oct 10, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
148 people viewed this question
Top Washing Machines Experts
