Shuts off after slowe burning ,8888 flashes, and all burner lights fash. Monitor 441 oil heater.
Monitor model 441 oil heater. After slow burning ,heater stops, and all burner lights flash, and 888 also flashes.
  • 4 more comments
  • rohgdrt Jan 19, 2008
    No help received.
  • rohgdrt Jan 20, 2008
    Approx. 8yr. old. Has been plugged into the same outlet entire life. Has not been turned on for 3 years.
    Heater is approx. 8 yrs. old. Has been plugged into same outlet. Has not been turned on i approx. 3 years.
    Still no solution
    How do I locate, and check,and, remove the senoliod pump. Anything I should be aware of to not do to prevent any damage in disassemblyig?
  • rohgdrt Jan 21, 2008
    Heater first comes on as it should. Warm air blows out at low speed, and half of the burner lights show. As heater attempts to go to high speed-fan- and heat it shuts down,all burner lights flash,and 88:88 flashes. Occasionally high heat will come on with high fan speedn and run correctly with blue flame for about two minutes. Heater shuts down with all burner lights, and 88:88 flashing. At first of high heat starting there is some yellow flame. I cleaned the fuel filter on the heater. It Needed it. For the short time heater runs at high heat it preforms as it should. Thank you for your help so far, but I still have the same problem. Up untill now this heater had run flawlessly for about 12 yrs., with no cleaning or maintenence. It appears to me the high heat makes it shut down. Heat too high shut off mechanism possibly bad?
  • 1,113 Answers
There is specific instruction on web site for 8888 code flashing, as bbtoast has instructed.
From a distance we are unable to do the test procedure, you will need to do it, follow the instructions given on THIS PAGE. you also will need a multimeter to test for the 2.4volts and also a 10K ohm resistor to test.
Without testing as instructed here are your options
shuts off after slowe burning ,8888 flashes, and a - 06c7dee.jpg plus failure of combustion motor.
Sorry no magic wand available, you will need to get your hands dirty, part identifiers and circuit diagrams are also on given site
I think you will find that Brian has already indicated this much and there is not anything more anybody could tell you.
Cheers.
Posted on Jan 20, 2008
  • 1 more comment
  • Soulvisitor
    Soulvisitor Jan 20, 2008
    part of page linked to previous
  • Soulvisitor
    Soulvisitor Jan 21, 2008
    once again same web site has part breakdown HERE
    Solenoid pump is number 9
    never done it myself, if you are not comfortable pulling it apart i suggest you hire a pro to do it.
  • Soulvisitor
    Soulvisitor Jan 24, 2008
    Did you try changing the fuel with fresh as suggested as well as the replacement of the filter that you completed?
  • 319 Answers
Have you looked at, and or followed the troubleshooting suggestions at this website?
There is a full troubleshooting guide for your model. Let me know if you have checked this site out, then give me more details as to any other indications.
How old is this unit, how long has it been plugged in to the current electric outlet, etc.
Thanks
Brian
Posted on Jan 19, 2008
  • 1 more comment
  • Brian Berndt
    Brian Berndt Jan 19, 2008
    Please also see the manufacturer website which is:
    http://monitorproducts.com/support/manua...
    Your manual is here:
    http://monitorproducts.com/pdf/manuals/m...
  • Brian Berndt
    Brian Berndt Jan 20, 2008
    OK
    Did you read the troubleshooting guide?
    I believe that you must have either followed the instructions, and it did not fix the problem?
    If so, I believe that you have an electrical problem inside of your unit.
    Are you able to perform this type of procedure?
    If not, then you should consult a suitable repairperson that is qualified to work on your equipment. If you followed the troubleshooting guide, please tell me what else you have determined.
    Thanks
    Brian
  • Brian Berndt
    If the unit has sat unused for 3 years, there may be other unknown issues. Kerosene that has sat more than 6 months becomes unstable, and condensation (water...think corrosion)can build up.
    I recommend a professional to look the unit over completely, as there may be more issues than are obvious.
    What I am saying is that you may replace the solenoid, and still have other problems, and still need service. But you will have already spent the money on the solenoid!
    Good Luck
    Scholar:
  • 128 Answers
Try this out. This is the monitor support site. http://www.monitorforpresident.com/contact.html
Hope this helps :)
Lennox 80uhg3-75a-3 igniter sometimes doesn't light , left LED slow flash, right LED solid.
The ignitor can crack and cause this, also check and clean the flame sensor.
Nov 25, 2013 | Heating & Cooling
Ihave a 441 monitor kerosene heater,burner status light are flashing and the heater shuts down.the heater has had a turnup, tank filter has been replaced, flow has been checked,igniter or flame dtecti
look and see if the part that stubs out the wick upon turning it off is stuck up or not dis engaging properly. if stuck up the over heating would shut it down!.
Jan 04, 2013 | Heating & Cooling
Burner lights but then shuts off after about a minute
What's happening is a good indication that the pilot assembly and the burner assembly may need cleaning. Insects can really clog it up. If after thoroughly cleaning the pilot and burner assemblies the burner still shuts off,check the gas tank and make sure it's at east 2/3rds full. After reconnecting the hose to the tank, open the tank valve VERY, VERY SLOWLY (Slow motion, slow) until the valve is full open. Then attempt to light the pilot and the burner. If every things works as it should, you solved the problem.
If you find you need to order a thermocouple, I have provided a link to the Blue Rhino Company, the manufacturer of Uniflame Patio Heaters and you can order it thru them.
http://www.uniflame.com/BRWEB/getdoc/3dbb047b-509e-4627-98cd-c4cdb36d82a9/Parts-and-Accessories.aspx
I hope this helped you troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 15, 2011 | Uniflame 200209 Open Flame Patio Heater
I have an endless summer 92000 table top propane heater. Lights fine, but the flame does not burn at the edge of the burner. Instead, it only burns in the very center of the burner... much like a Bunsen...
Actually, it's a gas pressure issue. But, it's fairly easy to solve. First, you need to be sure that your LP Tank has a sufficient amount of gas. If it does, turn the propane tank valve OFF. Disconnect the hose from the tank and wait 5 minutes. Then reconnect the hose to the tank and turn the valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, light the burner as you normally do and turn the burner flames to HIGH. Has the burner flame returned to normal? If so, you solved the problem. Just remember to always turn the tank valve ON very, very slowly.
If it didn't solve the problem, you will need to replace the heater's hose/regulator assembly. Generally, i's the same type that a gas grill uses. So, it won't be hard to find one.
Hope this helped to troubleshoot and solve your problem. Please let me know.
Apr 30, 2011 | Endless Summer 92000 Table Top Patio...
My 441 monitor heater will ignite and then it burns for a little while then goes out and starts flashing.
sounds like your heater may be starving for fuel. check all your rubber hoses for cracks first and then continue troubleshooting from there.
Nov 27, 2010 | Reddy Kerosene Heater with Thermostat:...
My 441 model monitor heater kicks on but cuts off in about ten
Mine cut off also. I thought it was the wall plug. But as it turned out, I took the cover off the back, cleaned the filter (kinda like a blow dryer clogs in the back) and it is working fine now..... Hope that helps...
Karen
Jan 04, 2010 | Heating & Cooling
MPI kerosene Monitor Heater
need to bleed air out of filter at oil tank crack open the screw on top it will bleed out air wait until oil starts to run out then tighten back and bleed at heater on right side lever inside hole push and let off slow 4-5 times and restart
Nov 02, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Operating manual for MPI monitor heater
You can obtain an electronic copy of the 441 owner's manual from http://www.monitorproducts.com/customer-support/manuals
Scroll towards the bottom of the page to find the 441 or 442 manuals.
Jan 09, 2008 | Heating & Cooling
Burner mat
it is a fiberglass composite. it will not burn. its function is to soak up the kero coming into the burner pot for ignition. from the factory it is held in place by a refractory cement that tends to dry out after time and the edges of the mat curl up. I do repairs on my own monitor 441 and I use a 500 degree silicone adhesive that I got from the hardware store made by rutland stove cements.
Dec 19, 2007 | Rinnai Toyostove Direct Vent Heater:...
Heating & Cooling Logo
2,011 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
