I just want to make the recommendation that you have a tech come and inspect this unit. for some reason it has line voltage to the heat strips at all time no switching. if your low voltage wiring were wrong and the sequencer had a constant 24 volts then it would do the same thing. the sequencer works by heating a metal strip to warp it into closing the circuit and it may be stuck.
Had this problem with 2006 Tempstar/ ICP /Carrier air handler (furnace) and the problem was the control board , where the big relay had melted/fused the contacts closed. Remedy was to replace the control board inside air handler access panel after shutting off power to the unit. Got replacement part on the internet by searching for the part number printed on the old control board.
