Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Flashing green light
TV has flashing green light. Tried all resets and power from the wall and no change.
  • candiv Apr 27, 2008
    No picture. Green light blinking. 1-2 times.
  • Kyle Monson May 01, 2008
    The power indicator light flashes continually ... never stops and cannot boot up far enough to even get to the diag codes. Have already replaced the Power supply capacitors, which is a very common problem with this model.
First I would try unpluging the set and let it sit for several hours. It may have parts that are on the edge that will work better cold. This next is not for the faint of heart. It involves completely dissembling the chassis to replace more caps on the FMT board where the DVI cable plugs in from the engine and or DM board sandwitched in the middle. I recomend a professional. Check out Nesda.com
Posted on May 03, 2008
    President:
  • 4,402 Answers
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Jan 19, 2008
Mitsubishi TV How do I fix green blinhing light in mitsubishi DLP TV 52825
most likely its a bad power supply. the wd52825 is known for that issue. check youtube for repair videos.
Jan 28, 2015 | Mitsubishi Televison & Video
My mitsubishi Model # WD-60737. It is lesss than a year old. The status light flashs green, the Mitsubishi blue start up page comes up the the tv cuts back off. I have unplug from the wall for an hour....
Tv under a year old call Misubishi for a warrenty repair.Flashes staus light mean could be any these parts have problems power supply board,Ballast board or the pojection lamp itself.
Jan 11, 2011 | Mitsubishi WD-60737 60 in. HDTV
Wd-62725 green light flashing continuously and TV will not Power
just happened to us, we unplugged in from the surge protector and plugged it in the regular wall outlet and were able to get the tv to come on, don't know why, but it worked
Apr 07, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Light flashing and tv won't turn on
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
134 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
