Question about Toshiba Satellite A135 Notebook
Screen Blacked Out...
Last night I'm playing some games on my laptop when it broke down.
the screen blacked out.
I've already tried resting it for 1 whole day.
but it's still having the same problems.
is the lights inside it the problem?
what should I do?
do I need to go to the repair shop?
thanks in advance.
  • 38 Answers
Before taking it for repair connect it to a working external monitor to verify the video card is working. It probably will. You most likely experienced an inverter failure. The inverter supplies the high voltage and frequency required to run the backlights. In some cases it is the backlight that fails. If you are comfortable taking apart the LCD putting a new inverter is easy, it just plugs in. Be sure and verify that the cable that goes through the hinge is intact If it is damaged it is inexpensive but requires taking apart the top and bottom to replace.
Posted on Jan 19, 2008
My screen blacked out using a game and won't come back on. I tried holding the ON button for a long time but it still doesn't come on. It is fully charged.
Some games require graphics card to be able to perform on enhanced level, if the screen blacks out during playing the game then it could be a driver corruption or registry issues..
Call 1-877-805-1027 for expert support..
Oct 19, 2015 | Amazon Kindle Fire HD 8.9"
I have a dell inspiron 1501 laptop. My computer was working fine last night but i fell asleep and left it on over night. Wwhen i tried to reboot my screen stayed on until it got the welcome screen after...
blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced.
Feb 27, 2013 | Computers & Internet
When playing my Snes only part of the picture appears while the rest remains black.
Well it might just be the fact that theese are old games and it happens to a lot of the older gamepacks and theese gamepacks are olut of date. qutips and rubbing alcohal
or the worst scenario is that your super NES cosole is on its way out then.
Apr 30, 2012 | Nintendo Super NES Console
Left side of screen blacked out,two or linnes in rest of screen
Hi there
The Problem is from the flex of your laptop.The flex is what connects the screen of your laptop to the motherboard of the laptop.The more you close and open the laptop the flex gets weak and that is what causes what you are seeing on your screen
To solve this problem get an expert to change the flex of your laptop for you
Cheers
Mar 03, 2010 | Toshiba Satellite P105-S6084 Notebook
Lenovo 3000 N200 laptop not starting up, power light on
Keep pressed the power button of your laptop for about 30 seconds, the machine will power down.
--The above step may not be required as already so many days passed by.
Then plug it into the power adapter.
Switch the laptop on.
Boot in "safe mode" (F8 during boot).
This will fix any driver or some operating system issue during previous failed boot process.
Once it boots completely, do a normal shutdown and reboot your laptop in standard mode (no more F8 this time).
Now your laptop will be ready to use.
Sep 30, 2009 | Lenovo 3000 N200 Notebook
Canon SD1000, screen blacked out and takes black pictures
try taking the batteries and memory card out let it set and put everything back in it ang cut it on
Jun 18, 2009 | Canon PowerShot SD1000 Digital Camera
1/2 screen Blk w 2" Stripes & UPSIDE DOWN/drop Dell Inspiron2200
well im not a great tech but i can give you one solution, you can try to connect it to ANY monitor from the VGA port of your laptop, just find a PC monitor to do this with. to "flip" the screen to different angles you will have to be logged on.
Hope this helps, i you have any further questions just ask
Apr 10, 2009 | Dell Inspiron 2200 Notebook
Screen Blacked Out
Try booting and entering the Bios settings, generally you hit delete while the system powers up, if the screen works fine here it is probably a windows resolution issue. You can press F8 before the system tries to load windows and enter safe mode. Reconfigure your resolution here and try it again.
Jan 19, 2008 | Toshiba Satellite A135 Notebook
Dell computer screen blacked out
Hello Sir,
Can you see any dull image on the screen, if yes, then The problem is with the inverter board in the LCD Screen,
Regards,
Aby
Dec 21, 2007 | AOC LM729 17" LCD Monitor
Toshiba Satellite A135 Notebook Logo
47 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
