Poss. bad ground for antenna to radio? hook the radio directly to the battery not to the cig lighter!!
Also, if the radio has been peaked and tuned the mic gain might be up to high, but it probably is that your swr's are too high.
check them on 1 and 40. use an inline meter, not the radio meter. if your swr's are lower on 1 thean 40, lower the whip. if 40 is lower than 1, raise the whip.
If its a magnet mount antenna and its stuck to metal, then its grounded.
What you probably have to do is tune the antenna for best SWR.
It is in your manual that you got with your cobra 29, and in the insturctions for the antenna.
Read them both, and tune the antenna accordingly.
The lenght of the antenna has to be just right. It will explain in the radio manual how to check the SWR to tell if the antenna is the right lenght and the antenna instructions will tell you how to adjust the lenght.
Also her is an artical on how to tune your antenna for best SWR. ARTICAL
IMPORTANT!! Do not transmit with your radio until you tune the antenna. If you SWR is to high then you could damage your radio.
Basicall if the antenna isn't the right length then the swr will be high which means that your transmit energy is not leaving the antenna but being reflected back to the radio and can blow the transmit circuit.
Thats why no one can understnad you good because all of the RF energy is not being transmitted. Its being reflected back.
