Question about Sony KP-57WS510 57" Rear Projection HDTV
GREEN AND PINK COLORS ARE SEPERATED PICTURE IS ARCHED TOP AND BOTTOM. HOW DO I REPAIR THIS??
  • Sony Master
  • 3,459 Answers
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
GREEN AND PINK COLORS ARE SEPERATED PICTURE IS - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Dec 11, 2009
SOURCE:
I have a slightly arched pink & green line accross the top of the screen.
I am wondering if we have the correct model number listed here? If so with the model listed either something is inside like a spider web or that model uses a optical light engine which "might" be able to do this if bad.
Nov 01, 2012 | Mitsubishi WD-60735 Projection Television
Pink and green colors seperated images rounded off
If colors are skewed and will not adjust in the customer menu---you have a CONVERGENCE circuit problem.
This model (KP-51WS500) uses two of the STK-392-560 convergence IC chips. I just got home from fixing a similar model with the same problem.
Parts cost on Ebay for the chips and such is going to be less than 30 dollars total. Shops are going to get 300 or more for this kind of repair---and some will not do it in your home---the repair takes about an hour--I have done hundreds of them here in people's homes.
If you have questions or need advice, reply to this posting and I will try to help.
If this told you something that helped you understand, rate this solution as I do this here for FREE.
SD TECH
Nov 14, 2009 | Sony KP-51WS500 51" Rear Projection...
Color seperation and red drooping line
You have defective Convergence IC's. It's best to have a service company verify and do the repair if you wish. Normally runs about $250.00
Jul 14, 2009 | Zenith R45W46 45" Rear Projection...
YOU CANN GREEN AND PINK SEPERATE
my t.v. turns off and on whatis the problem
Jan 28, 2009 | Philips 60P8341 60" Rear Projection...
Phillips 60in 60pp93/5217 red and green arch at bottom of screen
you need the convergence repair kit which contains both convergence ics and all resistors along with step by step instructions. heres a link to the site that has the repair kit.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Jan 21, 2009 | Philips 60PP9202 60" Rear Projection...
Color seems to be pealing up from the bottom of screen
If the screen is bouncing...expanding/shrinking you need to get a repair kit from www.TvRepairKits.com
If your screen looks 3d in color, has a stationary bow, or if you can't adjust one or more colors from the "convergence" menu you need to buy a convergence repair kit. You can get one from the same site listed above.
Hope this Helps,
Nov 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Convergence. shadowing, arch top and bottom, red and green colors
You have a convergence problem. i see these set all the time at shop. first consult the article in tips and tricks section the fl231 fuse problem. it might provide some answer and might turn out to be a simple repair. If you do not have the convergence option under setup in customer menu then i say you have that problem.. otherwise it sounds like a convergence power board issue. if you have the options try autocovergence first and then if that fails try manual convergence of red and blue if the dont move then it will be convergence power board. let me know and ill try to talk you through it
Oct 06, 2008 | RCA HD52W59 HDTV Projection Television
Arched picture at bottom seperating the green and red
Your tv has a convergance failure. the convergance ic's need to be replaced. Upgraded part # STK392-150 or STK392-160. Both ic's should be replaced to prevent future failure of other colors.
May 20, 2007 | Toshiba 43H70 43" Rear Projection...
Sony KP-57WS510 57" Rear Projection HDTV Logo
166 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
