Question about GE Monogram ZISS480DRSS Stainless Steel
Water dispenser problem
I have no water coming out my door water dispenser. I've checked inside the refrigerator to see if water is in the holding tank & not frozen. Everything seems to be OK. Any suggestions?
  • skaupert Feb 19, 2009
    We have the same fridge (48"). Water dispenser stops working intermittently. This happens typically in the morning, seemingly after it hasn't been used for more than 8 hours.
    Fridge is 6 years old. Problem started 4 days ago. When there is no water, there still is the familiar click from the solenoid, so the valve seems fine.
    The impression is that the water line is frozen inside the freezer door. But have not been able to confirm that.
    Problem Solver:
  • 9 Answers
Get a step ladder and push panel up at top to expose the compressor and wiring. Between the left and right there is nothing other than wire harness leading into the fridge. In this empty area toward the middle left is the watervalve easy to see. Unhook connections to watervalve and test for voltage to do this get a voltmeter put on AC setting put probes in each side of connection. Have some one push the despencer switch in and see if you get 120V if you do the watervalve is bad and needs replaced. If you don't get 120V than you have a short in the wire harness or the despencer control board has failed. Hope I helped.
Posted on Jan 20, 2008
Frigidaire Side-By-Side not dispensing water and possibly ice
It is possible the water line inside the refer is frozen, you will be able to see a resevoire or loop behind the bottom drawers that is where it could be frozen
Mar 24, 2014 | Frigidaire FRS6HR35K Side by Side...
Frigidaire refrigerator water filter area leaking
There has to be a loose or disconnected water line. Check the water dispenser inside the door and behind the door and then go from there.
Jul 23, 2012 | Frigidaire GS26HSZDW Side by Side...
How How do I fix my broken water line that goes in to the freezer door to the water dispenser?
The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 24, 2012 | Roper RS22AQXKQ Side by Side Refrigerator
No water from the water dispenser.
a new refrigerator has a water resevoir that has to fill up. you have to hold the water dispenser down for a minute or so to allow this resevoir to fill.
if you have done this already, then you probably have a bad water valve.
Jun 12, 2010 | Whirlpool GS6NBEXR Side by Side...
Why extra water line INSIDE my refrigerator
Hi, If you are talking about the tubing behind the crisper drawer, it is there to hold water for the dispenser in the door. The old design was a canister to hold water. Now it is tubing. I hope this helps you.
Vic
Jul 18, 2009 | Frigidaire FRS3R5EMB Side by Side...
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Water Dispenser not working
If the ice maker is working, and no water is coming out, the water line may be frozen.  This happened to me yesterday, and I followed the advice on ehow.com.  It worked like a charm! Take a hair dryer, and blow hot air up into the dispenser tube, holding the hair dryer about 8-10 inches away.  After about 5 minutes or so, a tiny chip of ice and a couple of drops may pop out.  Fill up a couple of glasses of water to flush it out, and you should be good!
Mar 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram ZISS480DRSS Stainless Steel Logo
134 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
