Question about ATI RADEON 9550 Graphic Card
Radeon 9950 AGP shows DDI Version is 9Ex in DXdiag but Windows Performance Information and Tools indicate the graphics card is "DirectX version: DirectX 8 or earlier"
I have ungraded by Pressario 1300NX to Vista.
I have installed the ATI RADEON 9550, AGP, including the latest drivers.
DirectX 10 is installed.
DXdiag shows DDI Version as 9Ex
AMD have recommended updating the AGP Chipset Drivers. I have downloaded the drivers from Compaq and installed them, but the problem remains.
Any suggestions?
  • 1,067 Answers
Re: Radeon 9950 AGP shows DDI Version is 9Ex in DXdiag ...
This card 1st off aint direct x 10 ready ok so remve that if u dl that update remove it all re dl 8.1 whatever new one is for yuors and dl new netframwork 2.0 also ok
Posted on Jan 21, 2008
0 characters
3 Points
9950 driver download for Windows 7 please.
Download the program (freeware) to find driver at that program and let it to scan your pc and finally find the appropriate driver.
Dec 12, 2013 | ATI RADEON 9550 Graphic Card
I have Windows 7 32bit and a 6200 512 AGP video card. My motherboard has 8X capability and set up properly in the bios. I have downloaded the latest Nvidea drivers for the card and they installed OK. When...
The reason for this is that your AGP video card only support DirectX 9.0 Shader Model 3.0 (pixel shader and it's operating at 2133 MB/s max - this is how fast it can fill up pixels in a video-game). The reason Windows is rating it low is because Windows tests your card on how many pixel it can shade in a 3-D graphics environment - since VGA operates in a parallel simultaneous transmission, it can only occupy 1 lane with a transfer rate of 2133MB/s at max - which is not bad with a subscore rating of 2.5 which is usually sufficient in the desktop graphics and 3?D graphics categories. In order for you to get a 3.0 and above rating for the video card, you must have a GPU that supports D3D (Direct 3D) v10.0, and pixel shader model 4.0.
Take note that the higher clock speed and pixel shader version of your video card, that faster it will get in 3D acceleration - thus higher video card rating.
Hope this information helps.
Sep 08, 2011 | Nvidia GeForce 6200 AGP Graphic Card
I have Zotac nvidia 8400GS 1GB DDR3 Graphic card i installed Directx 10 in my Computer (windowsXP-32-bit) but it shows pixel shader 3.0 and vertex shader 3.0 version Instead of 4.0 version Why it's...
Hi rajivqupta19,
DirectX 10 won't be compatible with earlier DirectX versions, and it won't be released for Windows XP. For backward compatibility with current games and hardware, Microsoft plans to include DirectX 9L in Windows Vista.
You can have a DX10 card in XP but you won't be able to use any of the DX10 features and optimization.
DX10 Windows Vista Exclusive according to the link below.
Additional Info Link
Shader 4.0 is for Windows Vista.
Hopefully this information helps.
Thank you for Using FixYa.
Sep 04, 2011 | PNY NVIDIA GeForce 8400GS Video Card
IMy video card is 82945G express chipset family, with a memory of 256mg. Does it have 100% dierctx compatibility? Also do you have any idea if it should be able to run medieval 2 (a game) on windows...
Your card does not have compatibility with Directx versions 10 or 11 but it might be able to run directx 9(to check this, type dxdiag in the search bar in the start menu and see what directx version pops up). It should be able to run medieval 2 but performance will be very, very choppy
May 13, 2011 | Intel Graphics Cards
I have not been able to add any AGP card to my PC.
My PC is a cube PC so I have been trying to install a "low end" AGP video card without a separate power connector. My only really requires are DirectX 9.x support and a minimum of 128MB (and no power connector)
The card I am currently trying to install is a Gigabyte ATI Radeon 9600Pro with 256MB.
I have also tried a ATI Radeon 9550 with 256MB and a Nvidia card
I have done all of the usual things, such as disabling onboard graphics, removing old video drivers, verified latest chipset drivers are installed, I reviewed the graphic adapter and don't see any conflicts etc.
I wonder if any of the cards I am trying to install will work with my AGP slot.
The manual for this Gigabyte card states "AGP 3.0 Slot or greater is required"
Unfortunately, this requirement wasn't on the Gigabyte or NewEgg web sites or the back of the box. Only in the install manual.
My Motherboard manual states "AGP 1.5v Card is required".
I got great AGP information from I used some of the tools suggested there such as Sandra Lite and other tools to try to determine what version my AGP Slot is. These tools don't seem to clearly state what
My PC is a Small Form Factor PC with 220W Power Supply.
It has integrated Intel Extreme Graphics
gBox P4 Blue CF-986L
Motherboard is a CFI-968L with last bios released (1.04)
Pentium 4 3.06Ghz
80G HD
Chipset is Intel 845GE
Windows XP Home
This is a awesome PC and I really would like to extend the life of it my adding any AGP card that supports DirectX 9.x
Read more: Adding ATI Radeon 9600Pro - AGP Slot Issue? - Tech Support Forum
Feb 28, 2011 | ATI RADEON 9600 Pro, (256 MB) AGP Graphic...
When i connect my graphics card to my pc i get a black screen there is no beeps and i cant even hear an windows sound. when i disconnect my gpu my pc works fine i have tried to disable onboard graphics...
Hello xvanpersiex, these are "Full Specifications" of your [Graghis Card].
"Check this to the 'Specs' of the "Motherboard to see if it 'Supports' the Graphic Card?"
"Try 'disconnecting, and reconnecting' the "Graphis Card"
Verify that 'all' the "Connections" are "Tightly Inserted."
*Go to the Control Panel > Device Manager > AGP Graphic Card > Verify Installed? >
Update Driver! > Restart Computer"
"If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9"
ATI Radeon X1650Pro (AGP 8x, 512MB) General
  • Device Type Graphics adapter
  • Enclosure Type Plug-in card
  • Vista Capability This graphics card is capable of running the new Aero interface featured in Windows Vista Home Premium and higher.
  • Interface Type AGP 8x
Processor / Memory
  • Graphics Processor / Vendor ATI Radeon X1650 Pro
  • Graphics Card Performance This card's graphics processor and memory mean that it is not recommended for most games, but it will still be fine for office applications and other normal computing tasks.
  • RAMDAC Clock Speed 400.0 MHz
  • Video Memory Installed 512.0 MB
  • Technology DDR2 SDRAM 128-bit
  • Features Avivo Technology
Video Input
  • Type None
Video Output
  • API Supported OpenGL 2.0,
    DirectX 9.0
  • Max Monitors Supported 2.0
  • TV Interface HDTV out
  • Analog Video Format S-Video,
    Composite video
  • Digital Video Standard Digital Visual Interface (DVI)
Expansion / Connectivity
  • Interfaces 1.0 x DVI-I (dual link) - 15 pin HD D-Sub (HD-15),
    1.0 x HDTV output - 29 pin combined DVI,
    1.0 x VGA
  • Compatible Slots 1.0 x AGP
  • Microsoft Certifications Certified for Windows Vista
Software / System Requirements
  • OS Required Microsoft Windows XP,
    Microsoft Windows XP Media Center Edition 2005,
    Microsoft Windows XP 64-bit Edition,
    Microsoft Windows Vista
  • Recommended Power Supply 350.0 Watt
  • Peripheral / Interface Devices CD-ROM
Feb 22, 2011 | ATI RADEON X1650 Graphic Card
Computer restarts on game start
Remove all traces of ATI drivers from add/remove programs and reboot before trying to install the newest Catalyst Control Center. The latest - 9.4 - does NOT have your card listed (they list the PCIe version, not AGP).
Recently ATI removed support for many of their "legacy" cards. 9.3 may be of more use to you.
Apr 13, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Desktop upgrade
Asus is a Solid MotherBoard manufacturer of mother boards. If you are looking for an add-on graphics card (I'm assuming you want to do some gaming), You would want to upgrade the memory for that motherboard to at least 1GIG which can be found here.
Graphics cards wise, I wouldn't advise anything higher then a $100 card... As that motherboard only supports 4x AGP (The type of connection your video card would use) and to get more for what you pay for, you really need a motherboard with an 8x AGP slot to get 100% of what you pay for. A Radeon 9950 at around $92 is the most you would want to put into a system that currently has a p4 2.66 ghz.
Mar 13, 2009 | ASUS Graphics Cards
Call of duty 4
Yes the game should run but at pretty low settings due to the graphics card :(
Dec 07, 2007 | Graphics Cards
AGP texture acceleration not avalable :(
Well your card is still an ATI & things have changed a bit. You don't just need the drivers but you need ATI's Catalyst Control Center. Through the Catalyst Control Center you have a ton of control that you just don't get with drivers alone. Suggest you update windows first. You'll need .Net framework 2.0 min. Do not skip lower versions of .Net framework & only install one at a time. Install DirectX 9.0c from Microsoft here:
Than download ATI's Catalyst Software Suite File size 46.6MB:
Uninstall any other versions currently installed on your system.
If for what ever reason the uninstall fails download and run ATI's uninstaller "cat-uninstaller.exe" to clean your system from here:
Don't forget to vote!
Dec 06, 2007 | Sapphire RADEON 7000, AGP Graphic Card
ATI RADEON 9550 Graphic Card Logo
5,727 people viewed this question
Top ATI Graphics Cards Experts
Brian Sullivan
Brian Sullivan
Are you an ATI Graphics Card Expert? Answer questions, earn points and help others
