This model has a know problem with parts called capacitors shorting out and causing the flashing that you have. If you can solder then you should be able to do the repair yourself. If you go to our web site at:
www.ccl-la.com and click on the monitor repair section I will post a step by step guide to the repair for you. You will need to replace 2 capacitors and yo should be back running again. Check after 12/09/09 at 2:00pm and the guide should be posted.
I hope this helps, f so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
