Question about Pentax Optio E10 Digital Camera
White Screen Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Posted on Apr 05, 2008
SOURCE:
How to fix an intermittent white screen on a Samsung television?
Ask them to replace the t-con board. It could be a defect one.Good Luck.
Serge.
Oct 01, 2015 | Samsung LNT3242H Television
White Screen
Normally there are two reasons for the given problem.
1). Bad or defective CCD. and/or
2). shutter not working.
in the first case the only solution is the replacement of the CCD.
Please click HERE
And in the later case sticking of shutter blade, non functioning of shutter blade will cause the problem. This can be rectified by sending it to some repairer.
Click HERE for the manual.
Main support number: 800-755-3854
I hope you are satisfied with my solution..
Goodluck..
Feb 21, 2008 | Fuji FinePix S5000 Digital Camera
Video issue macbookpro 2006
startup and regular sound White screen appears but no apple logo appear ,
1) smc have been reset multiple times. possible motherboard video hardware issue cause over heating.
2) hold option key switch on laptop it will be see hard disk or DVD drive (apple disk inside) icon, the motherboard good if icon appeared. and the motherboard video dead if not appear. hope to help a little
Jan 02, 2014 | Apple MacBook Pro with 17" Display
Acer All in one multi touch i5 Win7. Start all right, but then screen turn white. Can't see anything.
try reverting to vga mode
http://www.playtool.com/pages/safemode/safemode.html
tap f8 a couple of times after bios shows, then select vga mode in the list
if that works then you can change to a different resolution in display
Dec 31, 2013 | Acer Aspire Z3771-UR20P - P G630 2.7 GHz -...
I have NIKON L10. it takes the photos but all of them are not displayed... the screen becomes black on startup... whereas my old pics are dispalyed properly... i think i have problem in my lens....
try scanning the memory card with any antivirus software......
maybe its a problem due to virus. otherwise its a problem due to aperture the aperture jams during shutter clicking.
Aug 30, 2010 | Nikon COOLPIX L10 Digital Camera
Screen is all white
the display screen is faulty have an expert change it for you
Nov 07, 2009 | Computers & Internet
Black screen
Simply right click on the track itself and select send to/DVD-RW or CR-RW depending on the type Compact disc drive you have. Then you will see a notification, "you files to be written to CD." Simply click on it or go to your Compact disc drive on My Computer and click “write these files to CD.” Then follow the screen instructions. IT is that simple. All you need to do is press and release the display button until the screen displays. Usually Canon Powershot cameras have 3 display modes:- colour, black & white, blank. Your camera is set to blank that is why you cannot see any image/screen displays no image. Just press and release the display button until the screen displays. That should do it.
Sep 13, 2009 | Canon PowerShot A620 Digital Camera
Won't Take Pictures
My nikon coolpix 4500 has the flashing red clock as well with the hands of the clock pointed to 9 oclock and a white dot on the oppostie side of the 9
Dec 28, 2007 | Cameras
Won't Take Pictures
contact nikon they know about the problem and will fix it for free
Sep 02, 2006 | Nikon Coolpix 5700 Digital Camera
Pentax Optio E10 Digital Camera Logo
425 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
