Question about Bosch WFMC 3200 Front Load Washer
Belt repair how do i put a belt on a washing machine? small pulley or large first?
  • 139 Answers
Put it on the small pully first and then the large one..
put it on the large pulley ( i call it a drum flywheel) and rotate in a direction walking the belt onto the wheel hope this helps any questions dont hesitate to ask
Posted on Jan 21, 2008
How to change drive belt
disconnect power, remove the belt guard, spin the small pulley while derailiing the belt from the large pulley. To install, put the belt on the small pulley and then on the large pulley while rotating the spinning parts by hand, easier to turn the small pulley, guide the belt into the large pulley groove.
Apr 16, 2015 | Air Tools & Compressors
The belt on my Kenmore washer model no. 110.45091401 is shredded. How do I replace it?
REMOVE BACK PANEL ON FRONT LOAD WASHER PUT BELT ON LARGE PULLEY AND TAPE BELT TO LARGE PULLEY TAKE OTHER SIDE OF BELT AND STRETCH TO MOTOR PULLEY WHILE ROATING LARGE PULLEY WALKING BELT ONTO SMALL PULLEY OR LOSEN MOTOR BRACKET PAY ATTENTION TO LOCATION OF MOTOR BRACKET ALIGNMENT PUT BELT ON BOTH PULLEYS PUSH MOTOR TILL BELT IS TIGHT AND RETIGHTEN BELT
Jan 26, 2011 | Kenmore Washing Machines
Install belt on Amana top load washing machine
Use the correct sized belt!!
Loosen the Motor mounting Bolts. ( Do not take it off ) Now the motor assembly can be moved towards the opposite large pulley.
Replace the belt in this position and slide the motor to it's original position. You adjust it in such away so that, the belt is not too tight or loose!
Apr 05, 2010 | Amana ALW895 Top Load Washer
Haier HLP21E belt broke. My machine was overloaded. How do I replace it?
put new belt on big pulley first then roll in over on smaller one
Mar 29, 2010 | Haier HLP21E Top Load Washer
Electrolux front loader.EWF1090 i have the replacement belt but am having trouble fitting it. belt seems too tight. is same as the roken one. any suggestions?
put it on the small pulley first, then hold it on the large pulley with your hand and slowly turn the big drum, ensuring the belt stays on the big pulley as you move it. line up where you place the belt on the small motor pulley with the drum or it may slip off again.
Dec 23, 2009 | Electrolux Washing Machines
How do I replace the belt on this machine
take the back off and put the on the small pulley and pull the belt over the large pulley
Apr 20, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Replacing a belt on a frigidaire glft1670a
First remove the top of the unit by taking out the 4 screws at the back of the machine. After the screws are removed, push the top foreward and lift it off. Next, remove all of the screws on the back of the machine and remove the rear cover. The belt should be infront of you now. If your belt is broken or worn, go buy a new one. Put the belt in the grooves of the motor pulley first. Hold the belt onto the pulley while you use the other hand to start the belt onto the wash tub pulley. Slowly rotate the large tub pully and feed the belt on fron the motor pulley. There will be a fair amount of pressure and this is normal. Keep turning the large pulley until the belt slips on fully. Spin the large pulley a few rotations to make sure the belt is centred and is in the proper grooves of the motor pulley. Now replace the back cover and top in the reverse order.
Feb 10, 2009 | Frigidaire GLTF1670A Front Load Washer
Margherita 2000
put belt on motor pulley. start belt onto large pulley. turn large pulley by hand so belt will slip on. does require some strength
Sep 07, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Putting belt on top load amana washer moder #unknown
There is a large pulley directly under the washer drum that runs the transmission. There is a small one connected to the motor shaft, and a third which is attached to a spring-arm and acts as a tensioner.
Pay attention to the direction the tensioner moves. The back of the belt should go against the inside of the tensioner when it is released.
The easiest way I've found to get the belt back on is to thread it around the small pulley, and tensioner, then start it on one side of the large pulley, and rotate the large pulley to allow the belt to thread onto it.
Hope this helps.
Aug 13, 2008 | Amana NAV5805A Top Load Washer
How to put the belt on,
there is no way of tensioning the belt so it is a very tight fit
put belt round motor pulley first then start belt on large pulley and turn large pulley by hand and it should go on
Jun 24, 2008 | Washing Machines
Bosch WFMC 3200 Front Load Washer Logo
65 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
