Psp shows comms error for internet
A dns error has occured (80410411)
not able to use internet function can you help the system shows 100% reception an connection
DIDN'T WORK
I HAD THE SAME PROLEM WHEN I FIRST GOT MY PSP AND TRYED TO SET UP TO ACCESS THE INTERNET.
THIS WORKED FOR ME, CLICK ON THE INTERNET BROWSER SETTINGS UNDER THE NETWORK TAB, CONNECTED TO INTERNET IF YOU HAVE A BT HOME HUB THIS WILL APPEASR ON THE SCEEN.
IF THIS DOSEN'T WORK YOU NEED TO CHANGE THE FIREWALL SETTING ON YOU ROUTER
Ok, this problem has happened to me before, and most commonly the problem relies on a wrong inputed password on your psp. Double check the password you put into the psp is the same one you have for your entire network. If you are continuing to have problems try unplugging the modem and router for about 15 second and connect them again. Good Luck!
