Question about LG RU-27FB30C TV
Hot overheats hot st2310hi was shorted replaced with nte 2642, new trans.overheats no hv.
  • toyota2001 Jan 21, 2008
    i fixed it it was a cap,shorting to horiz,heatsink.
  • toyota2001 Jan 27, 2008
    Hi i fixed it,it was a cap shorting to horiz.out.heatsink.
  • LG Master
  • 5,138 Answers
If this is your hori out put it means you have a bad flyback transfomer.
Posted on Jan 19, 2008
6ya staff
SOURCE:
2004,Mazda 6,4cyl,battery gets really hot,and now automatic transmission will not shift stays in 3rd, replaced battery, and is still doing same thing
SOUNDS LIKE ONE PROBLEM CAUSING 2.BRAKE FEEL MUSHY? FROZEN CALIPERS HOLDING BACK TRANS-RACING MOTOR CAUSING OVERHEATING BATTERY? OR.... BAD TRANS CAUSES RACING MOTOR TO OVERHEAT BATTERY.? SOUNDS LIKE 1-(CAUSE) SLIPPING TRANS , RACING ENGINE,,BATT OVERHEATS ETC........DEPENDS ON WHICH STARTS FIRST-TRANS ISSUE, 2 ENGINE RACING, 3 HOT BATTERY? THAT EQUALS A PUZZLE READY TO BE SOLVED. IF YOUR BRAKE SYSTEM WHERE IN GOOD SHAPE (EMERG BK TOO) I WOULD LEAN TOWARD THE TRANS FROM HERE. GOOD LUCK, FRANK M (PS, DONT KEEP CHANGING YOUR BATT BECAUSE OF THIS,THE ALTERNATOR IS OVERCHARGING THE BATT DUE TO THE RACING OF THE ENGINE DUE TO EVERYTHING ELSE. GO FOR THE CORE!
Feb 14, 2016 | Cars & Trucks
Do we have a transistor which is equivalent to d718
NTE36 is allegedly equivalent.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jan 08, 2014 | Nte D718 Equivalent NTE36 NPN high power...
2.6L Mighty Max 4x4 1988 has a blown head gasket...where would you look for a resonable rebuilt short / long block...or do you think it's worth trying to do a gasket replacement...189k miles...we live...
I'd at least invest some time and remove the head and look to see what you are working with. Have the head dye tested and also checked for warpage. if the head is OK, then do the gasket. If you severely overheated it, or if you had other engine problems before the head gasket failed, then I'd get a replacement engine ( many choices available from local craigslist, scrapyards and rebuilders ). Be sure to find the cause of the overheat that led to the gasket failure, otherwise you can do the same thing to the new one. If it's an automatic trans car, change the trans fluid also as it breaks down when it gets too hot.
May 21, 2011 | 1988 Mitsubishi Mighty Max
HV trans was burnt and replaced,oven needs reset ,does not currently work .has error overheat.
did you replace the fuse also.
if not then go ahead and do that first.
Thanks
please rate my work
Jan 10, 2011 | TurboChef TORNADO Electric Oven
WMH1162 not heating
Sorry to read about your problem, You have a major failure, I suggest you contact a service company. If you feel like making repairs yourself, i will give you some pointers below.
There are other variations depending on whether the cooling fan, oven light, and so forth are located down stream of the fuse.
Some models may have a separate high voltage fuse. If this is blown, there will be no heating but no other symptoms. However, high voltage fuses are somewhat rare on domestic ovens.
A number of failures can result in the fuse NOT blowing but still no heat:
  • Bad connections - these may be almost anywhere in the microwave generator or the primary circuit of the HV transformer. A common location is at the crimp connections to the magnetron filament as they are high current and can overheat and result in no or intermittent contact.
  • Open thermal protector - usually located on magnetron case. Test for continuity. It should read as a dead short - near zero ohms.
  • Open thermal fuse - some ovens have one of these in the primary circuit. It may be in either connection to the HV transformer or elsewhere. Test for continuity. It should read as a dead short - near zero ohms.
  • Open HV capacitor - see the section: A shorted HV capacitor would likely immediately blow the fuse.
  • Open HV diode - see the section:
  • Open magnetron filament - This failure may also be due to loose, burnt, or deteriorated press (Fast-on) lugs for the filament connections and not an actual magnetron problem.
  • Open winding in HV transformer.
  • Defective HV relay. A few models use a relay in the actual high voltage circuitry (rather than the primary) to regulate cooking power. This may have dirty or burnt contacts, a defective coil, or bad connections
  • Shorted HV diode -
  • Short or other fault in the magnetron - see the section:
  • Short in certain portions of the HV wiring.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 30, 2010 | Whirlpool Microwave Ovens
Hi, my wife drives a 2000 merc. sable wagon 3.0 l dohc last week she leaked major trans. fluid, a puddle and a line of fluid for about 16ft. she parked it. I filled the trans 4 to 5 hrs later with new...
Yes the front pump seals on long extended drives xway very hot it can expand have seen this a lot in my trans shop over the last 20 yrs the trans will have to come out to repair this. big job!
Aug 07, 2010 | 2000 Mercury Sable
Amp in protect mode how to fix
good in mode 2 protects from damaging unit u probaly have output wires touchin or inpt wires touching or shorted speaker if does not fix problem diconnect car batt 4 2min this resets pwm circut if no fix u probbaly have shorted opt transitors not expense 2 repair 4parts go2 nte semiconductor.com tran 2/3$ apice probally need 2 4 good luck
Apr 08, 2009 | Car Audio & Video
What would cause a fuel pump to overheat
When the fuel pump is short circuit it will start going bad and thus gets hot. Replace witha brand new one. It will not cost much.
Rate this
Mar 24, 2009 | 2000 GMC Sonoma Extended Cab
2004 dodge ram is over heating, the thermostat and fan clutch have been replaced.Doesn't(over heat) in cool weather,but will in mod. weather if driven over 70mph or hilly terrain due or increase of rpm,and...
Water pumps can stall out, but do you have air trapped in system.
Had you recently had the system "open" to replace hose, thermostat, temp sensor. Some Ford and GM have a bleeder screw on a high point in cooling system to bleed out trapped air.
Check your trans fluid color. Since the trans cooler is built into radiator (automatics)
IF the engine is overheating the trans CAN overheat
IF the trans is overheating the engine CAN overheat
They share the same cooling source and trans fluid gets hotter than oil, but yet it has a wimpy cooler built into radiator. Maybe add trans oil cooler to system.
Also outside temp affects the cool down rate of the radiator, ie...hot air trying to cool down hot radiator/engine is less effecting than cool air cooling hot radiator/engine
Aug 06, 2008 | Dodge Pickup Cars & Trucks
Hot over heats
add more fans they sell those on ebay 4 pack that runs off ac outlet suck that hot air out faster
Jan 19, 2008 | LG RU-27FB30C TV
LG RU-27FB30C TV Logo
63 people viewed this question
Ekse
RONALD CARTER JR
