Question about Cameras
Fujifim finepix f11
Fujifilm f11 camera won't switch on, battery has been charged and is in the right way. Have just returned from sub zero temperatures, woul that have any effect.
    Problem Solver:
  • 15 Answers
All the camera battery systems are tricky in some degree. Try to check:
1. Batteries in a voltmeter after charged. Some batteries drop dead without warning regardless the time they spend in the charger. Once dead, they have to be replaced
2. Cleanness of electric contacts.
3. Proper pressure of electric contacts, mainly when springs are present.
I owned a Olympus C2000Z with same problem.
Posted on Jun 28, 2009
    Scholar:
  • 51 Answers
Did it operate in sub-zero conditions? Was it warmed back up when you tried it last? Do you have another battery to try?
If the battery is really OK then I wonder if the extreme cold could have caused something to move, dosconnect or break because of the cold and movement caused by contraction, due to cold.
If it is really dead it is not worth fooling with other than it might be woth a try to bang it around a little and see if it re-connects the broken connection. Can't hurt!
Posted on Jan 20, 2008
Won`t turn on
Did you install the battery the correct way? The orange square on the battery indicates it goes perpendicular to the orange battery tab. Is the battery fully charged? If you place the battery facing the other way where the orange box is to the right of the orange tab then the battery won't lock in place naturally.
Feb 04, 2014 | Fujifilm FinePix HS50EXR Digital Camera...
Finepix jv300
The problem could be bvattery failure, especially if it dies right after charging
Mar 21, 2013 | Fujifilm FinePix JV300 Digital Camera -...
It is not charging,the charger is all right
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 23, 2012 | FUJIFILM FinePix Z35 Digital Camera
Fujifilm xp30 that won't turn on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Dec 16, 2011 | FUJIFILM FinePix XP30 Digital Camera
I get an err messasge when the camera is turned on.Also I would be interested in a service for the camera. How to get it to you, and how long for return, and cost? David Plessas
If "Err" is displayed on the LCD panel on the top of the camera when the "MENU/EXE" button on the FinePix S1 Pro is pressed, check the following:
<If "Err" is not flashing>
1. If the slot cover is open, switch the camera off, close the slot cover and switch the camera back on.
2. If the remaining charge in the AA-size batteries is low, switch the camera off, replace the batteries and switch the camera back on.
3. If steps 1 and 2 above do not remedy the problem, contact the store where you purchased the camera or your nearest authorized FUJIFILM repair center.
<If "Err" is flashing>
1. Pictures cannot be taken because the remaining charge in the lithium batteries is too low or because the camera mechanism has stopped operating due to the camera being used in cold conditions.
In this event, switch the camera off, replace the batteries and then switch the camera back on. If replacing the batteries does not resolve the problem, set the focusing mode to "M" and release the shutter before switching the camera off briefly.
2. If step 1 above does not resolve the problem, contact the store where you purchased the camera or your nearest authorized FUJIFILM dealer.
Please click here to download the manual for Fuji FinePix S1Pro .
You must have Adobe Acrobat Reader installed to view PDF files. The reader is a free plug-in available at the Adobe web site.
Oct 11, 2011 | Fuji FinePix S1 Pro Digital Camera
How do you set the time and date on a fujifim jv100 camera
Press the MENU/OK button to bring up the menu. Press cursor-left to select a left tab. Use cursor-up/down to select SET. Press cursor-right to enter the setup menu. Use cursor-up/down to select "DATE/TIME" and press cursor-right.
The full instructions are in "The Setup Menu" section of the manual (page 71 in my copy). If you need the manual, you can download one at
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/j/finepix_jv150_manual_01.pdf
(Yes, the filename says "jv150", but it's the manual for the JV100-series cameras).
Jun 09, 2011 | FUJIFILM FinePix JV100 Digital Camera
I have a fujifilm digital camera its a finepixv10 i plugged the wrong charger into it now it will not turn on , can you help ?
As you have used wrong charger so you have to see if the problem is withe the camera or FUJIFILM FinePix V10 Zoom battery, Or if the battery haven't been charged by the charger, so the power is empty and you can't turn on camera, Then use a right FinePix V10 Zoom battery charger..
Apr 26, 2011 | Cameras
FinePix J10 Digital Camera: I have just bought a fujifilm J30 camera. I have i...
Did you put in the battery the right way? If yes, try cleaning the contact points on the battery.
May 17, 2010 | Fuji FinePix J10 Digital Camera
I lost terminal adapter for fujifilm F11
You can get a replacement charger from any Fuji stockist or even ebay.
May 03, 2010 | Fuji FinePix F11 Digital Camera
Cameras Logo
83 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
