Question about Kodak EasyShare CX7300 Digital Camera
No power camera suddenly stopped working. recharged batteries no result, changed batteries still nopower tried batteries in different camera they worked perfect. camera has never been knocked or dropped,
  • 2 more comments
  • Anonymous Mar 24, 2008
    The camera turns off even if it has new batteries.
  • ekohc May 17, 2008
    The same problem.. when i turn on my camera, first blinks green light then red as the result camera shut down. I dunno what to do.
  • Anonymous Aug 02, 2008
    camera wont turn on
  • Anonymous Dec 04, 2008
    Mine did the same exact thing but i droped my any ideas on how i might be able to fix it
Directly from Kodak's website:
We recommend that you do not use alkaline batteries in EasyShare cameras because they may cause unexpected shutdowns and loss of pictures.
Posted on Sep 12, 2008
  • vongross Sep 12, 2008
    Refer to this guide:
    Or you can use other branded batteries similar to these.
I had this problem . and it pursisted for the lifetime for the camera. i was using the alk. battr. may this damaged my set. i consulted with kodak service guys. they gave me a 9000/- + repairing solution!!!:)
so i repaired it from the local camera repairer. it was 2500/-(INR).now it is okay and delivering a great quality pic. though i have nikon D70 and my new D300, i kept it for some sort of use. dont leave it. it is a very wonderful camera except that battery consumption.
Posted on Oct 01, 2008
I have a polaroid i634 that has an issue with power. Initially I put in alkaline batteries and it worked for awhile (or at least as long as my daughter used it). Then it stopped working. I was told to use...
Hello ..
I hope that really problem with charging.
However, it look like cause from battery. Whatever type of new battery that you used, that no meet the requirement as original battery that included with camera. During testing the camera, they also don't use other battery except that original battery. Maybe it seem like have same power, But it chemistry is different. However, you can try using same battery from polaroid also.
TRy look here
I don't want to scare you, but is good to have new battery same like original and also from same company. As long you are using other type battery, It maybe will effect components in camera. So beware and careful.
If you think that charging is problem. THen try recharge back around 8hours. However if u are using external charger. and not using camera to charge battery.If you only can charge through camera, try recharge around 2-3 hours. Pull out battery from camera. place safely and avoid any magnectic environment . Around 2-1 hours, charge again 2-3 hours. After charge, around 10-15 minutes, try used it. It still have problem? If still face same problem. I advice to find suitable battery.
Jul 06, 2011 | Polaroid i634 Digital Camera
My S9600 was left unused [batteries left in camera] for several months. Now it will work fine with the mains adaptor, but is completely dead when on battery power. Have tried new batteries [rechargeable...
Sounds like corrosion on the battery contacts. I have seen battery contacts with a thin, transparent coating that came from leaking rechargeable batteries- doesn't look like the usual green crud, but it stops electricity from getting through. Try giving the contacts a scrape- you will need a long thin screwdriver or something of the sort.
Dec 01, 2010 | Fuji Finepix S9600 Digital Camera
We have a cannon a2000is. After replacing the batteries and printing the pictures off the memory card the camera will not come back on. The screen says Cannon and the indicator light blinks for aprox 20...
It sounds like a low power startup. Are you sure the batteries that you are installing are good? If they're Dollar Store "Super Heavy Duty" batteries, that's likely your problem (shelf life has been exceeded).
Recommend trying to start the camera with premium alkaline, or best yet, rechargeable batteries (they have the most power, and save you money too!). If the above doesn't work, recommend contacting Canon, especially if your camera is less than a year old. The camera in that case would be eligible for warranty repair.
Oct 15, 2010 | Cameras
Kodak m1073 dont open
The problem you describe is frequently the result of dirty/corroded battery contacts in the camera. Try removing the batteries and cleaning the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue left from the cleaning, then replace the batteries. Hopefully all will be well.
If the cleaning doesn't work you might want to check the Kodak troubleshooting guide at:
Aug 08, 2009 | Kodak EasyShare M1073 IS Digital Camera
Low Battery
Many Kodak brand cameras have this problem, and when I say many I mean almost all. The only solution is to try different types/brands of batteries until you find one that lasts.
Jan 17, 2009 | Kodak EasyShare C875 Digital Camera
You can try switching over to 2500 mAh Nickel Metal Hydride rechargeable batteries and you will see a difference.
Digital cameras with zoom lens need more power than what can be supplied by ordinary batteries.
May 24, 2008 | HP Photosmart M22 Digital Camera
Camera Won't Turn On
if your having battery problems then i suggest recharables...i got energizer AA rechargeable set and it works perfectly for me...hope this helps :D
Mar 25, 2008 | Samsung Digimax D53 Digital Camera
"change the batteries"--but they're new batteries!
I had the same issue which cleared itself up when I used digital specific batteries (theoretically higher power) as well as replaced the cr1220 battery (in a small gray plastic slot next to the 4 AA batteries).
Jun 13, 2007 | Canon PowerShot S2 IS Digital Camera
Power problem
is there a reset access hole?
Jun 04, 2007 | Sony Cyber-Shot DSC-P31 Digital Camera
Rechargeable Batteries
This is a triky one. Most cameras will work with rechargeable batteries. If they don't work the most probable cause is this: a normal battery has about 1.5 V nominal charge. Because you use 2 of them you get 3 V nominal charge. Most rechargeable batteries have about 1.21 - 1.25 V like yours. This is given by the technology type used in their construction. However 2 1.25V batteries will result in 2.50 V at nominal charge and some cameras woun't go whell with the 0.5 V difference. You should try other types of rechargeable batteries, maybe some of them will work, but it is recomandable to do that before you buy them, so like I said, it's a triky choice. Try to go to a digital camera shop, they may sell rechargeable batteries more compatible with your camera.
Mar 11, 2007 | Fuji FinePix A500 Digital Camera
Kodak EasyShare CX7300 Digital Camera Logo
156 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
