Question about Oracle 10g Database Standard (ODBSEONUPP0)
MS DATA DUPLICATE Problems
Dear i want to some data Delete on access Table But i have Not give Any Unique this table and i wnat to deleted no more than one
Ur a knob, get sum english lessons
Posted on Sep 08, 2008
    Novelist:
    Scholar:
  • 108 Answers
You will need to state your problem Taru with a bit more explanation but to try to point you in the right direction....right clicking and clearing the contents of a cell, row or column works if I remember correctly.
Posted on Jan 24, 2008
Undelete records from access table
ou can try to use third party Access recovery utility to restore your lost and damaged data from .mdb files. For more details about this software:-
Access File Recovery
Apr 17, 2009 | Microsoft Access 2000 (077-01277) for PC
Application and example of relationship in access
Relationships
After you've set up multiple tables in your Microsoft Access database, you need a way of telling Access how to bring that information back together again. The first step in this process is to define relationships between your tables. After you've done that, you can create queries, forms, and reports to display information from several tables at once.
A relationship works by matching data in key fields - usually a field with the same name in both tables. In most cases, these matching fields are the primary key from one table, which provides a unique identifier for each record, and a foreign key in the other table. For example, teachers can be associated with the students they're responsible for by creating a relationship between the teacher's table and the student's table using the TeacherID fields.
Having met the criteria above, follow these steps for creating relationships between tables.
  1. In the database window view, at the top, click on Tools ---> Relationships
  2. Select the Tables you want to link together, by clicking on them and selecting the Add Button
  3. Drag the primary key of the Parent table (Teacher in this case), and drop it into the same field in the Child table (Student in this case.)
  4. Select Enforce Referential Integrity
    • When the Cascade Update Related Fields check box is set, changing a primary key value in the primary table automatically updates the matching value in all related records.
    • When the Cascade Delete Related Records check box is set, deleting a record in the primary table deletes any related records in the related table
  5. Click Create and Save the Relationship
Apr 09, 2009 | Microsoft Computers & Internet
Write into excel format
Your code does not save in access format it just makes a copy of existing file. You need to open table by table and export data using csv format.
It can be done using access OLE to export, or
write some VB code to access the database tables via ODBC and save row data to csv file
Feb 17, 2009 | Microsoft Visual Basic Professional...
How to export table in ms access to excel
yes you can export your access data into excel, follow steps on how to export.
1. open your access database
2. open the table data you to export
3. under table data view click tools menu
4. select analyze
5. select ms excel
6. this will open your seleted access table in excel
hope this will help you..
Dec 13, 2008 | Microsoft Access 2002 for PC
Connectivity between HTML page and Ms-Access
<HTML>
<BODY>
Set MyConn = Server.CreateObject("ADODB.Connection")
MdbFilePath = Server.MapPath("sample.mdb")
MyConn.Open "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & MdbFilePath & ";"
SQL_query = "SELECT * FROM Friends"
Set RS = MyConn.Execute(SQL_query)
WHILE NOT RS.EOF
<LI><%=RS("Name")%>: <A HREF="<%=RS("Link")%>">Homepage</A>
RS.MoveNext
WEND
</BODY>
</HTML>
Nov 11, 2008 | Microsoft Office Standard for PC
How to use passwd character in a table in ms-access 2003
When you create table where you want to store passwords, go to Edit Table, then select a field where the password will be stored, go to Input Mask field in Properties and type Password in that field. That will set up the field needed for storing passwords.
Aug 18, 2008 | Microsoft Office Access 2003 (077-02871)...
Access 2000 database won't compact and repair.
mchampion,
You are in luck. I had the same problem a while back. Most of the time you will not be able to compact and repair a database that has reached capacity, however, you can import the database into a new one. The first thing you are going to have to do is find a very large table in your database and copy it into a new one. Then, delete that table from your old database. Now, open another new database. Go to the file menu and choose import. Now you must find your database in the directory and click it. Now choose one of the given options (tables, queries, etc.). Then, Press control + a to select all items. Now hit okay and it will import all of the items from your old database from that section into the new one. You must do this for each section (tables, queries, etc.). When everything is imported (should take less than an hour), compact and repar the new database. This will give you additional space to work with. Now you can bring in the table that you copied into a new database earlier the same way (import). This should put you back in business.
I suggest creating a 2nd database for any other data you may want to add later. You can always make link tables and such in your old database in order to get the additional data and prevent crashing your old database.
Let me know if you need any additional help.
ArthurB
Apr 24, 2008 | Computers & Internet
Duplicacy in excel sheet
Since you are searching the data by the phone number , first select all the data in the spreadsheet and sort it in ascending order by the phone number.
Then, assuming you have 5 columns of data A through E, and the phone numbers are in column E, with row 1 occupied by column headings, use the following formula in cell F2=IF(E2=E1,"Duplicate",1)
Drag this formula down column F till the end of your data
Select the entire data and do an auto filter
In column F filter the data by Duplicate and delete all these rows
What remains should be unique data
Dec 19, 2007 | Computers & Internet
Ms access
before this u should know what is databse.
ms access has various objects likw table,form,query,report etc..
table is a object which stores the actual data and form is used to enter the data in to the table and display the data from the table, while report is object which is used to desplay your data in required formate.Query is used to fetch the data from the table in customised formate.for that u should have knowledge of SQL.
Nov 14, 2007 | Computers & Internet
Oracle 10g Database Standard (ODBSEONUPP0) Logo
70 people viewed this question
Top Oracle Computers & Internet Experts
Bonded Repair
JonSnell Electronic
JonSnell Electronic
 steve
steve
Are you an Oracle Computer and Internet Expert? Answer questions, earn points and help others
