Question about ASUS A9550GE/TD Radeon 9550 Graphic Card
Games resolution hi..i alreay install this graphic card but when i play game (esp PES6), after a while, the images running slow a bit. Is it related with the graphic setting or my desktop setting?
    Sergeant:
    Champion:
  • 243 Answers
Try dropping the resoltution that the game plays at. Also turn down any "eye candy" settings. Also stop any background progs running via task manager to allow max power to be used for game performance
Posted on Jan 20, 2008
6ya staff
SOURCE:
Asus EAH5450
Hi Friend,
You Computer and Graphics card all things is good configuration. Some tips you follow.
A> If you PC virus infected then slow down you PC.
B> RAM memory increase because high HD game not support or slow speed problem.
C> Check you internet speed connection, because you are live game play.
D> And finally not solved then you re-install windows and again all driver proper install.
I hope solved you problem.
Aug 26, 2013 | Dell OptiPlex Computers & Internet
My graphic card asus eah4350 dnt run smooth game at more than 1200x720 !!!
Hi adarsh9022,
first tell me what graphic card you are using,
The way i look it is due to you graphic card because it is not support higher resolution try to lower down the graphics setting in game and disable vsync also lower down other advanced setting in game.
Jan 25, 2013 | Computers & Internet
I just bought a Samsung RV510 laptop with Windows 7 Home Premium 64 bit with a Intel Dual core proccessor 2.4 Ghz< 4 Gigs of Ram. The video card says it is a Intel Graphics media accelerator driver for...
Laptops are not made to play games on, there graphic cards are not made for it. there are a few things you can try though.
Try running the games in windowed mode instead of full screen.
Try updating the video driver.
Try lowering the game resolution.
Hope this helps
Jul 03, 2011 | Samsung RV510A01 T4500 23G 4GB 320GBDVD...
I can not play a game properly.my system becomes very slow,how can i play a game perfectly
If your experiencing a game latency or sometime called log, you can try changing the resolution of the game or the quality of graphics, or you can also upgrade the graphic card and memory of your pc.
Hope this one helps you.
Thanx
Apr 02, 2011 | HP Computers & Internet
The screen flickers when I am playing games requiring a high resolution. I sometimes have to turn the monitor on and off a couple of times before I get to see anything on the screen. Most times the images...
If it's a few years old the power inverter could be going, otherwise it likes to run at the "native resolution" all monitiors have a "naitive resolution" i just means the resolution that the manufacturer recomends. It should be in your booklet, also diagnosing games is tough because they are graphic intense. There is a site called "can I run it" that will tell you if your machine can run specific tests. I play Call of duty modern warfare, And with dual SLI video cards I just about run it, with a dual core and 2 gigs of ram. This is subjective at best. also the refresh rate on your monitor plays a big role in these games, anything slower than 5ms is too slow for most new games. Mine are 1 and 2 MS. check the box ou the game it will tell you the minimums
May 24, 2010 | AOC 917Sw 19" LCD Monitor
My vostro 200 on call of duty 4 runs slow !! I
try lowering the screen resolution in the game settings also ste the grphics quality to low then see if the game is running fast if it runs fine then increase the graphics options one by one like resolution , bilinear or anisotropic filtering , antialiasing etc
and i would also like to tell you one thing that if the graphics card was inbuilt in your laptop then don't expect it to play heavy games like this you will have to install a separate graphics card to play good quality games
Apr 30, 2009 | Computers & Internet
Screen goes blank when I start up game...
why don't you go with the lower resolution itself as it was before.  if you are not able to set the screen resoultion to lower what you can do is reset ur system. press F8 key continuesly untill you get advanced boot system. There you select "safe mode" and run the system. Once it is booted try changing the resolution.             OR After getting the Advanced boot system you can also try by selecting "Last Known good Config......" so that it sets the old screen resolution...!
Mar 18, 2009 | Nvidia WinFast GeForce4 MX4000 128MB DDR...
Black screen when starting up game
can you change you screen resolution to the same as your game is running at.
there is usually a safe mode to you can reset video options
Id say try the forums related to the game it may be a common problem there
hope this helps
Jan 05, 2009 | Vision Xtasy 9200 SE (64 MB) Graphic Card
Aspire M1641 - can't play games (super slow)
There could be several reasons that is so:
  1. The PC may not meet the minimum requirements for the game. These include screen resolution, graphics card, memory, sound capability.
  2. The graphics card may not meet the requirements of the game - memory, graphics rendering capability etc.
  3. The operating system may not meet the requirements of the game eg ActiveX, DirectX etc. All these are related with graphics/display capability.
Please check the MINIMUM REQUIREMENTS for the game and make sure your PC meets these.
All the best!
Dec 13, 2008 | Acer Aspire M1641-U1521A PC Desktop
Fx5200 agp card
Well running vista on nvidia 5200 and expect for performance is nothing but a dream.If you are a gamer, you shoud REALLY get a new graphic board...an nvidia 8600 could help you.the rest of the configuration is great for running vista and play most of the games(with a new graphic board).
IF you don't need another graphic board and you don't play demanding games, the video driver could be your enemy...
here is a site where you could download a GOOD driver www.Guru3d.com
Cheers, mate!
Sep 03, 2008 | Galaxie VDO 128MB NVIDIA FX5200 AGP 8X TV...
ASUS A9550GE/TD Radeon 9550 Graphic Card Logo
299 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
