Question about Apple iPod nano
New I pod nano will not turn on or show any signs of life. Tried holding menu and center button down with no luck
    Guru:
  • 158 Answers
I think your ipod is dead. This happened to me to. I was listening to it when I arrived at my destination, and I thought I turned it off and I put it in my pocket. Later that day when I went to listen to it, it wouldn't turn on at all. Aparently, it had stayed on. Hold the pause button for five to ten seconds. The apple symbol will appear on your ipod. Immeadility put it in your docking station before it goes away. Your ipod will turn on, and itwill start charging. TRY THE PAUSE BUTTON.
I'm sorry if I was too late. I hope this helps. Please rate my solution.
Posted on Dec 03, 2008
Did you try connecting it to the computer? sometimes this helps.
Posted on Jan 20, 2008
My I pod 16gb nano screen turns pure white everytime I turn it on. How can I fix it?
Try holding down the Center and Menu buttons simultaneously and dont let go until the screen shows you the Apple logo. That is the proper way to reset it.
Hope this helps. Thank you for using FixYa.
Sep 01, 2010 | Computers & Internet
My i-pod won't turn on and I don't have i-tunes
Move slide button to left.
Hold down center button.
Press and hold down Menu.
When apple symbol appears let both buttons go.
You can download Itunes here>
http://www.apple.com/itunes/download/
Jul 01, 2009 | Apple iPod nano MP3 Player
My i pod nano 1gb wont turn off
when its on just hold the play button till it turns off.
Nov 22, 2008 | Apple iPod nano
Ipod nano won't turn on
Hold down the center button and the menu button at the same time until you see signs of life!
Nov 09, 2008 | Audio Players & Recorders
I pod nano
Don't forget to toggle the hold key on and off first. The whole process may take a few tries.
Here's a page at apple. Different types of ipods have different key combos to reset them.
http://docs.info.apple.com/article.html?artnum=61705
Mar 13, 2008 | Apple iPod nano
Ipod not turning on/not recharging
Have you tried holding down the menu button and the middle circle button?
first place your ipos somewhere flat and press down the circle button and the menu button,make sure your not touching any other part of the click wheel.hold them down for about 5 seconds untill the apple logo appears.then let go,and it should be back to normal.you can use this procedure any time that it freezes or stops working.Hope fully that should fix your problem.if not i suggest you get it repaired under your warrenty.
Good Luck.
Regards.
Sophie
Feb 13, 2008 | Apple iPod nano 3rd Generation
IPod does not turn on or show up on the comp! NO SIGN OF LIFE!
Hi! I have the second generation iPod nano and just experienced the same problem. However, one of my friends gave me this advice. Maybe it'll help you too. If you iPod doesn't turn on or doesn't show up on the computer what you do is hold down the menu and select or center button for seven seconds. It'll reset without deleting your music or anything. I hope this helps.
-MKSC
Dec 05, 2007 | Apple iPod nano
Unlock code to use
how can i unlock my ipod
Nov 26, 2007 | Apple iPod nano
My mini ipod freezing, showing charger sign i could not turn it to menu
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 14, 2007 | Apple iPod mini M9160LL/A MP3 Player
Apple iPod nano Logo
59 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
